Determine Exact Year Of Car
Posted 19 November 2010 - 05:23 PM
I need to determine the exact year of this Austin Cooper (not an S) that I bought a few months ago. It needs some body parts. I'm pretty sure it was brought into the U.S. as used because it doesn't meet U.S. spec for the year on the title which is 1972. The VIN tag doesn't properly indicate the year. The electric system is more like a late 70s-80s car (4 fuse). The door glass is one piece (no wind wings). The electric switches are 4 rockers that are the shorter type and it has dip switch on left stalk, wiper on right stalk. Left hand drive. The shifter is the short one that comes out of the floor just in front of the seats. Options that I know of are rear window defrost and brake check. Any Ideas out there of where to look for an answer?
Thanks guys
Posted 19 November 2010 - 05:29 PM
The cooper ( not S ) stopped production at MK2 so pre 69, then only resumed in the 90's with RSP and Carbed cooper.
Put a picture up and most people will be able to tell you what it was originally..
Edited by Guess-Works.com, 19 November 2010 - 05:30 PM.
Posted 19 November 2010 - 06:52 PM
Sounds like you have a 're-plated' newer car, which is not uncommon in the US...
Posted 19 November 2010 - 07:00 PM
Edited by bardan, 19 November 2010 - 09:08 PM.
Posted 19 November 2010 - 07:43 PM
although your mini has MK2 rear lights and earlier single speedo
Posted 19 November 2010 - 07:44 PM
The year of manufacture for various parts of the car is stamped ino them. This isn't always the build year of the actual car, but can give you an idea. The trunk latch and wiper motor have a date stamped in and the windshield may have a code of dots by the manufacturers name that will reveal the age.
Posted 19 November 2010 - 07:57 PM
What is the UK registration hidden behind your Arizona plates?
UK plate # GAH249K
Posted 19 November 2010 - 08:07 PM
UK plate # GAH249K
that would be 1971
Posted 19 November 2010 - 08:09 PM
There's very little dateable stuff left on that car that was original to it. I think it looks like an '88 car though from what I can see. Can you post a photo showing the engine and routing of the heater hoses?
Posted 19 November 2010 - 08:25 PM
That's what we call a suffix plate so the year is represented by the K at the end, it relates to the '72 car that has been destroyed by someone in order to make your car look older than it is.
The boot latch date is 15-86. The wiper is 5-85. The engine is an A+. The heater hose routing was from the coolant pump hose to the intake manifold then to the firewall. I'm having problems uploading more pix
Posted 19 November 2010 - 09:18 PM
Posted 19 November 2010 - 10:56 PM
Posted 20 November 2010 - 12:30 AM
No little rectangular lights on side of fenders or evidence of wiring. The wiring going to the starter looks original, but I'll check for regulator. I 'll look under the door cards for a date (I might get lucky). I never thought it might be a RHD conversion to LHD, just because it looks like too much work to be worth the effort, but now I'll be open minded to that and take a closer look. Dan, I think you might have it narrowed down to a few years plus or minus. ThanksOk, I've seen the updated photos. I was going on the route of a heater hose in one of the earlier photos when I said '88 but someone has changed the heater layout entirely in your car. I'd happily accept that as an '86 car based on the component stamps and the general build of what might still be original. Does it have the small rectangular turn signal repeater lamps above the front wheels? Or wiring for them? These were introduced during '86 but given that the car has some '85 dated parts it's probably an early '86 car from before the lamps were introduced. The starter was changed from innertia to pre-engaged during '85 so using those two change points you could nail it down to within a few months. Even when people swap things like the starter and ring gear they tend to leave evidence of what they have done in the wiring. If it was originally built as a pre-engaged car for example it will have a starter relay on the RH inner wing, just ahead of where your wiper motor would be if the RHD/LHD conversion had been done by someone competant! In fact, going by the way this car seems to have been hastily converted, check that the steering rack has been swapped for a LHD one and not just turned upside down because it will wear out quickly and handle poorly if mounted upside-down. Also check that LHD pedals have been fitted, having the wrong pedals makes the driving position feel very odd. My own car was subject to a very poor conversion the other way around by a previous owner and I had a LHD clutch pedal for years before I worked out why my foot was so far under the heater.
Posted 20 November 2010 - 08:03 AM
It's what called a "Heinz 57" or "Bitsa"....
Posted 20 November 2010 - 11:19 AM
It would, indeed, handle poorly.... it would go left when you turn the steering wheel right!!
If the washer bottle is original, and it's not something that would normally be changed, it is pre 1988.
As GW says, it's a 1275, probably from a Metro.
Can't quite make out from the picture... do the two water hoses going to the heater enter close to each other (2" or so apart) or is one right at the top of the heater box?
Close = 1984 to 1991.
Top and bottom of heater = Pre 1984.
Edited by ado15, 20 November 2010 - 11:42 AM.
