Hi
I have just got some bullet mirrors off of ebay. I have tried to trial fit a mirror on a refurbed door I've got. I can see that I am going to need to drill a couple of new holes for the bolts, but my problem is getting the bolts up inside the door and screwed into the mirror. I stripped the door completely but still cannot gain access. Please could someone enlighten me on how they have fitted theirs.
Thanks in advance for your advice.
Fitting bullet mirrors
adscooper
, Dec 17 2005 07:41 PM
6 replies to this topic
Posted 17 December 2005 - 07:41 PM
Posted 17 December 2005 - 10:09 PM
when i fitted mine, i was able to get the rear bolt into the mirror, nimble fingers and all, but the front one was a nightmare.
what i had to do was to drill a hole on the inside of the car door, this was pluged up with a rubber grommet, after fitting.
they look good, but dont expect to be able to use the passanger one, as a mirror, i cant see anything worth while out of it.
Posted 17 December 2005 - 10:13 PM
Spanner with masking tape across the 1 side, hold the nut in place using the spanner and masking tape
Posted 17 December 2005 - 11:57 PM
Or do what i did when taking off/re-fitting mine
Get someone with small fingers to do it for ya (thanks lil sis) :tongue:
Posted 18 December 2005 - 12:37 PM
Cheers guys for your quick replies. Gunna give it a go this afternoon.
Thanks again.
Thanks again.
Posted 18 December 2005 - 11:55 PM
As for the mirrors. Fit them at an angle. You will have a hole under the mirror bracket in the door. I just simply put a Domed Chrome nut and bolt in it. Looked good.
Both mirrors are also 100% useable too.
Posted 21 December 2005 - 06:14 PM
i bought 'tex' bullet mirrors and they came with the black plastic base plates and fitted a treat. plus fully moveable so both mirrors can be used.
