you want me to build the loom and fit it for you?
ahahahahahah i just want to get it completely right and not get it all wrong for once ahahah
Posted 17 December 2010 - 08:44 PM
Posted 17 December 2010 - 11:49 PM
haynes manual.
you need to tap into the blue/white wire that comes off the stalks. Wire that through a switch to a relay (mounted on the inner wing so it's close to the starter terminal.) Then you use the relay to power the lamps. I think i posted a wiring diagram on here not long ago, so have a search for my posts.
edit: I didn't. oops! Here's one anyway...
Posted 18 December 2010 - 12:15 AM
Posted 18 December 2010 - 12:57 PM
Posted 18 December 2010 - 04:04 PM
you'll see the numbers on the bottom of the relay itself.
Posted 18 December 2010 - 04:11 PM
My blue switch
the red one is for radio sw. live
Posted 18 December 2010 - 04:52 PM
no i meant, does it matter which numbers each thing is in?
or can they be in any of them?
Posted 18 December 2010 - 05:56 PM
Posted 18 December 2010 - 07:30 PM
i just remember same as knowing what gear im in, i always remember to switch them off with oncomeing traffic unless the on coming guy has HID's
