My Fixerupper
#16
Posted 26 April 2011 - 06:46 PM
#17
Posted 26 April 2011 - 06:56 PM
#18
Posted 26 April 2011 - 07:18 PM
#19
Posted 26 April 2011 - 07:27 PM
No probs with getting anything to do with engineering or fabrication up here, we're in the middle of the north sea oil industry and have been since the mid seventies. Tons of engineering and supply shops, only problem is things can be a little more expensive than normal so it's a case of pay a little more locally or save and ebayGood work on the mini and fabrication. How do manage when you run out of welding tips, drill bits etc in Shetland? Can you get stuff easily on the island?
#20
Posted 28 April 2011 - 06:14 PM
Like to make a little comment on this, i can get whatever i need no probs EXCEPT any unf thread bolt/machine screw other than a plain nut or bolt!! Tried to get a countersunk machine screw (the ones that go in the door hinges) and all i got was blank stares. Ended up getting a metric thread and will have to drill and tap.Can't even get stainless unf! Seems like everyone has moved on from the seventies.Good work on the mini and fabrication. How do manage when you run out of welding tips, drill bits etc in Shetland? Can you get stuff easily on the island?
#21
Posted 28 April 2011 - 06:30 PM
Still you are progressing well.
#22
Posted 28 April 2011 - 08:21 PM
Cheers, and yes it's rotten! Seemed like a good idea at the time! But i'll get there. I found a set of ten screws for the hinges on minipreservation.com for £2, minispares does 1 for £1.50!Have you tried Smiffy's bits http://www.smiffysbits.co.uk/ stainless steel bolts, screws etc so no need to mess around re tapping things for metric. I am so glad our clubbie is not that rotten, it was bad enough with Project Erm.
#23
Posted 02 May 2011 - 06:52 PM
Getting started on the drivers side floor now. Today i managed to sort out the sub mount at the toe board and did the front sub mount on the bulkhead. I've made it out of some 1.5mm plate, same on both sides. Wondering if this is going to be strong enough. I've got solid mounts on the front sub just now but i'm thinking of changing the rear ones on the front sub to poly ones to save on stress. Whats your experence of this? Found out today that my smokey old 1275 is actually a 1330! So hopefully will be turning it into a sweet torquey one instead! There's a couple of pics of the old floor as well, three sills on it!! Weighed a ton!
Edited by skoughi, 30 June 2016 - 08:35 PM.
#24
Posted 03 July 2011 - 03:57 PM
Posted 03 July 2011 - 04:12 PM
Posted 03 July 2011 - 04:20 PM
#27
Posted 09 July 2011 - 08:52 AM
Posted 22 July 2011 - 01:31 PM
Posted 22 July 2011 - 02:04 PM
#30
Posted 22 July 2011 - 06:37 PM
