Anyone Know What These Are?
21 replies to this topic
#1 benmoffat
benmoffat
  • 347 posts
Posted 28 December 2010 - 07:38 PM
Hi all,
Attempting putting my front subframe together at the mo but got some bits Im not sure of.
Can anyone tell me what these 2 bits are for and where they go please?
Thanks very much.
#2 rustandoil
rustandoil
  • 317 posts
Posted 28 December 2010 - 07:42 PM
They are brackets that go to the top of the radiator
#3 benmoffat
benmoffat
  • 347 posts
Posted 28 December 2010 - 07:43 PM
Ok. Thank you rustandoil.
Ben
#4 minus
minus
  • 13 posts
Posted 10 January 2012 - 05:50 PM
Are you using the z-cars radiator and if not, what radiator are you using. I've read that the z-cars one is the same or similar to one from a Fiat Uno
#5 rustandoil
rustandoil
  • 317 posts
Posted 10 January 2012 - 06:15 PM
To clarify
Fiat UNO radiator when using the standard mini subframe with the Z-Cars "crash bar"
When using the Z-Cars tubular front subframe a different radiator is used, I bought mine from Zeds and unfortunately has no identification marks on it :(
#6 benmoffat
benmoffat
  • 347 posts
Posted 10 January 2012 - 06:47 PM
Just to let you know Im also using the rad that came in the Zcars kit,
This one http://zcars.org.uk/...es/radiator.jpg
#7 rustandoil
rustandoil
  • 317 posts
Posted 11 January 2012 - 06:48 AM
Any useful part numbers on that box ? ;)
#8 minus
minus
  • 13 posts
Posted 11 January 2012 - 07:17 PM
I'm using the Z-Cars tubular front subframe. What is the height and length of the z-cars rad ?
#9 benmoffat
benmoffat
  • 347 posts
Posted 11 January 2012 - 08:15 PM
Thats not actually my photo its from the zcars website. But I do have some numbers for you.
Width = 580mm
Height = 400mm
There is a label saying its from euro car parts and "radiator various VW 1.4" They can be had on 0845 602 2585 (although the label is dated 2010)
Theres also these number in the label if you want to quote this to them
203 44 1201
69122
C/N 199
Hope that helps.
Edited by benmoffat, 11 January 2012 - 08:15 PM.
#10 minus
minus
  • 13 posts
Posted 11 January 2012 - 08:30 PM
Euro Car Parts part no 203441201 is a radiator for a VW Lupo 1.4. So, yes that helps thanks.
#11 rustandoil
rustandoil
  • 317 posts
Posted 12 January 2012 - 06:11 PM
Useful numbers for the future maybe ;)
#12 benmoffat
benmoffat
  • 347 posts
Posted 12 January 2012 - 08:43 PM
Yea sure is, just now hoping a rad for a little 1.4 lupo is going to be up to cooling a 2 litre turbo thats shut in a bulkhead! Soon find out if its not,
#13 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 13 January 2012 - 08:45 AM
It will work fine, my coolant sits at around 81degC whilst cruising and fans kick in at 87degC, never seen it above 89degC.
If you dont intend on using your engine coolant driven heater matrix in the car I suggest that you block off the unused pipes, dont put a bypass pipe (a simple pipe to bypass the removed heater matrix) on as the water will choose that route before wanting to get pushed to the front of the car to be cooled.
I am about to stick a chargecooler radiator in front of mine so that might have an effect on its performance but I dont see it being an issue when driving at speed, it might take a bit longer to cool when the fans are on.....
Edited by cptkirk, 13 January 2012 - 08:46 AM.
#14 benmoffat
benmoffat
  • 347 posts
Posted 13 January 2012 - 05:35 PM
Thanks for the info cptkirk. Im not going to have a heater in mine so will have a look at doing what you suggested.
#15 KTM kid
KTM kid
  • 227 posts
  • Local Club: Crews missels
Posted 16 January 2012 - 12:22 AM
the rad is also the same as a VW polo I believe.
