Lil Grey
#46
Posted 04 September 2016 - 09:25 PM
JohnR
#47
Posted 06 September 2016 - 10:42 AM
Like the black and white shots of the engine - very atmospheric! keep up the good work!
JohnR
thanks, its a bit hard off late to keep up the arty arty but main thing is car is getting completed
#48
Posted 06 February 2017 - 08:40 AM
#49
Posted 13 February 2017 - 08:18 AM
#50
Posted 13 February 2017 - 08:44 AM
#51
Posted 18 April 2017 - 12:33 PM
#52
Posted 24 April 2017 - 07:43 AM
Saturday i went and fetched lee so he could come help me with things that are just easier with 2 people.
- Fitted new front heated windscreen (this took a surprisingly longtime however this story is embarrassing so i wont go into it)
- Bleed brakes and clutch
- Used a laser spirit level to get the wheels straighter
Lee also noticed that i couldn't get reverse since rebuilding the gear linkage. Turns out i had the bottom plate on the wrong way around. I have to admit i didnt really think when i put that on to much just wanted it on the car. Another reason why you have friends look over your car lol.
So the car finally saw wheels for the first time in over 1 year, forgot how low they are!
Sunday i fitted the battery and tested most off the electronics. Main think i needed to do was ensure that the Nodiz and EWP80 all worked. At first they never but turned out i hadnt had the correct switched live spade terminal from the original coil feed on the loom. Once that was corrected things started to light up... good news!
Also after an hour or so faffing with laptops i finally got it to speak to the Nodiz so i converted my old MJ Map using the new software and loaded it onto the unit.
Thats all i did this weekend. This week i suppose its time to get it ready to start and bed in the cam.
#53
Posted 29 April 2017 - 07:55 PM
been busting my balls this week with nearly every moment i can spare between work and the misses trying to do the odd task here and there.
#54
Posted 10 May 2017 - 08:28 AM
#55
Posted 10 May 2017 - 08:24 PM
Amazing build , hope it goes really well, probably one of the best minis out there when it gets finished
#56
Posted 11 May 2017 - 06:33 AM
thanks for the kind words. i wouldnt say best as the shell needs some TLC but thats for a later date.
#57
Posted 22 May 2017 - 07:22 AM
Edited by t@z, 22 May 2017 - 09:16 AM.
#58
Posted 22 May 2017 - 12:19 PM
What type of brake line that is your using? And where did you get it from?
#59
Posted 22 May 2017 - 05:08 PM
Getting there mate!
all my brake lines, breather pipes and oil cooler set up if from these gents..... http://www.thinkauto.com i would highly recommend them to anyone!!
#60
Posted 22 May 2017 - 05:35 PM
Getting there mate!
Thanks for that, I don't suppose you remember the name of the pipe/connections? If not no worries, ill give them a call.
