Front Windscreen Aperture
4 replies to this topic
#1 BusheyTrader
BusheyTrader
  • 485 posts
  • Local Club: Nope
Posted 22 January 2011 - 06:41 PM
Hi,
After drilling through the sound spot welds in the centre and prising away flaky metal at the sides, the scuttle panel is off.
Before removing it, the central measurement between the top and bottom of the windscreen hole was 415mm. I had sound metal to measure from. Left and right of that the scuttle flange was crumbly and fell away when the windcreen rubber was removed.
Is there any reason why 415mm isn't the gap to the left and right? The bulkhead flange seems to dip down with the scuttle flange standing proud but I didn't have sound scuttle to measure from.
Thanks in advance,
Adam
#2 wassupcrew
wassupcrew
  • 502 posts
Posted 22 January 2011 - 09:07 PM
just measured mine for you. in the middles its 410mm and about 4 inches in from each end its 405mm. hope that helps
#3 BusheyTrader
BusheyTrader
  • 485 posts
  • Local Club: Nope
Posted 23 January 2011 - 01:46 PM
Thanks, much appreciated............
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 23 January 2011 - 01:49 PM
Is it a genuine or pattern scuttle that you're fitting?
#5 BusheyTrader
BusheyTrader
  • 485 posts
  • Local Club: Nope
Posted 23 January 2011 - 09:54 PM
I've read too much about the fit of pattern panels so its genuine.
Minispares is only a few miles away which helps...........
