do you have to remove the bottom arm or can you do it with it still attached.
cheers
sean
Edited by sheepy89, 12 February 2011 - 12:24 PM.
Posted 12 February 2011 - 12:23 PM
Posted 12 February 2011 - 12:29 PM
we are in the middle of replacing the suspension cones on the front of my 1986 mayfair and have come to a problem. how do you get the cone out of the subframe??
cheers
sean
Posted 12 February 2011 - 12:31 PM
Posted 12 February 2011 - 12:32 PM
Posted 12 February 2011 - 12:33 PM
Posted 12 February 2011 - 12:37 PM
we have the knuckle and trumpet out we just cant get the actual cone itself out. we are just putting it back the way we found it just with new knuckles and new rubber cone
Posted 12 February 2011 - 12:42 PM
a number of people on here said that you didn't need to remove the upper arm to get the rubber cone out.
Posted 12 February 2011 - 12:43 PM
Posted 12 February 2011 - 12:47 PM
Posted 12 February 2011 - 12:49 PM
Posted 12 February 2011 - 12:52 PM
Posted 12 February 2011 - 01:29 PM
Posted 12 February 2011 - 02:29 PM
Posted 12 February 2011 - 02:35 PM
Posted 12 February 2011 - 02:48 PM
just been out to buy a ball joint splitter and it doesnt fit over the ball joint enough to screw the screw down onto it to split it. are all ball joint splitters the same size?
