1993 Rover Mini Rio
Posted 18 February 2011 - 10:58 AM
For sale is my 1993 Rover Mini Rio. It has 66107 miles on the clock
Am selling as I can no longer afford to run 2 cars. Since owning it I have sorted all the rust areas, replaced the radiator cap, radiator hose, thermostat,fitted a new battery and alternator, a new wiper motor, I have changed the oil and replaced the clutch fluid, replaced the rocker cover gasket,exhaust gasket and head gasket and also had the head skimmed. It has speakers in the back parcel shelf and a 6 CD auto changer. The changer isn't working so may be removed but the head unit still works so that will stay so you can still use it as a radio or cassette player and a new changer could be fitted very easily. The previous owner converted the back windows to open and fitted some chrome interior trim bits for the door handles, gear knob and hand brake as well as a racing steering wheel and I have fitted a new red carpet. Also it has had an immobilizer fitted. There was some rust on the scuttle panel which I have removed and fixed up the wholes and re painted. The finish isnt perfect (see picture) as I was planning on a colour change in the future so was going to get get it looking perfect when I did that, but it would be an easy job for even a beginner to do and I will throw in the filler/paints if the buyer wants. Its completely water tight just could do with abit of a fix up. As you can tell I have put alot of work into it and will be sad to see it go. Most of the mot's and other work was all done by a mini specialist and all the reciepts are present. Tax and mot till July so ready to drive away.Located in Colchester.
Pictures
http://i.ebayimg.com/02/!CF01M4g!2...,!~~_12.JPG
http://i.ebayimg.com/01/!CF01BEQCWk~...QHSoRw~~_12.JPG
http://i.ebayimg.com/20/!CF01DRg!W...QO3BTg~~_12.JPG
http://i.ebayimg.com/18/!CF01Kbw!m...#33;DQ~~_12.JPG
http://i.ebayimg.com/06/!CF01GcgEGk~...QZ6TZg~~_12.JPG
Thanks for any advice
Posted 18 February 2011 - 11:44 AM
i would say the price is about right but unfortunatly people dont seem to know what a rio is. maybe putting in the advert that its limited edition and the last LE with carbs, not many made etc (750 i think)
Edit: and first with the larger seats
Edited by adam_93rio, 18 February 2011 - 11:47 AM.
Posted 18 February 2011 - 12:53 PM
Posted 18 February 2011 - 01:15 PM
'AVV IT', although i agree with you in a way: i wouldnt be put of by the mention of filler, it has a bad name but does have a propper use. and if used properly it will be a more professional job than if not used at all. its just a shame people use it so much to fill holes completely.
Posted 18 February 2011 - 09:47 PM
Posted 18 February 2011 - 10:42 PM
Posted 18 February 2011 - 10:46 PM
Posted 18 February 2011 - 11:40 PM
Posted 19 February 2011 - 06:22 AM
Oh don't get me wrong, I do appreciate that it does have a proper use (i.e. for skim filling small dents and scratches etc.) I just meant that I would be wary of it having been used to repair areas of corrosion like it seems to have been on this guys scuttle.
Posted 19 February 2011 - 07:40 PM
This topic is locked
