Mini Cbr-xx
28 replies to this topic
#1 daveyp
daveyp
  • 28 posts
Posted 22 February 2011 - 09:04 PM
Hi all, myself and my engineer/fabricator friend Jimmy are currently building a blackbird rear engined RWD mini (well Jimmy's doing most of the building, I'm just supplying a long list of parts/metal!)
The mini is a '79 round nose 850 originally which I bought with the intention of reliving a bit of my youth having had a few minis in the distant past, but as you all probably know these things have a habit of snowballing into something that you had no intention of doing.
We are currently fabricating the rear frame/suspension mounts etc, and the diff is also being converted to run the sprocket and a new casing made for it (xr4x4 diff, shafts and drive flanges etc). Its going to run on ford gear front and back, with a spaceframe front end as well, similar to z cars but hopefully a bit cheaper!
I will try and post some photos when I figure out how to get them from my phone into here.
regards Dave
#2 miniblade81
miniblade81
  • 218 posts
Posted 22 February 2011 - 09:08 PM
good look with build keep posting
#3 daveyp
daveyp
  • 28 posts
Posted 22 February 2011 - 09:44 PM
Hi again, have managed to extract some pics from the phone, gives an idea of what stage its at. Been neglected for a few weeks because Jimmy so busy with 'normal' work.
ETA on the road early summer hopefully. Wiil post progress as it happens.
cheers Dave
Attached File  mail.virgin.net.jpg   4.49K   16 downloads
Attached File  mail.virgin.net_2.jpg   10.65K   12 downloads
Attached File  mail.virgin.net_3.jpg   10.5K   15 downloads
Attached File  mail.virgin.net_4.jpg   9.6K   11 downloads
Attached File  mail.virgin.net_5.jpg   6.58K   12 downloads
#4 daveeeeee
daveeeeee
  • 684 posts
Posted 23 February 2011 - 11:04 PM
Cool. Keep it coming!
#5 daveyp
daveyp
  • 28 posts
Posted 26 February 2011 - 05:27 PM
Hi again, some recent progress to update- some views of the cut away floor and the fixing flange to keep the floor tight, new floor pans and cage fixings and the rear drive flanges and tubes, also pic of the ( bit dusty) power plant , 160 horses of screaming honda power. Jimmy putting a lot of thought into the rear frame at the minute so should have some pics in the near future as it takes shape.
Do apologize for some of the pics being inverted- ok if you've got a laptop, not so handy if its a desktop!
cheers dave
Attached File  IMG00170_20110225_1011.jpg   153.07K   11 downloads Attached File  IMG00171_20110225_1011.jpg   129.55K   12 downloads
Attached File  IMG00172_20110225_1012.jpg   163.71K   12 downloadsAttached File  IMG00173_20110225_1013.jpg   175.22K   8 downloads3.jpg]
Attached File  IMG00174_20110225_1013.jpg   200.19K   15 downloadsAttached File  IMG00175_20110225_1015.jpg   145.56K   35 downloads5.jpg]
Attached File  IMG00176_20110225_1016.jpg   126.72K   17 downloadsAttached File  IMG00177_20110225_1016.jpg   113.26K   21 downloads6.jpg]
Attached File  IMG00178_20110225_1016.jpg   157.51K   15 downloads
Attached File  IMG00179_20110225_1017.jpg   159.76K   26 downloadsAttached File  IMG00180_20110225_1018.jpg   173.67K   22 downloads8.jpg]
Attached File  IMG00181_20110225_1018.jpg   156.84K   18 downloads
#6 miniblade81
miniblade81
  • 218 posts
Posted 21 March 2011 - 06:18 PM
any updates
#7 MINI-TURBO
MINI-TURBO
  • 230 posts
Posted 20 April 2011 - 10:01 AM
looks realy good, keep it up. im getting a custom spaceframe made for my R1 mini.
#8 daveyp
daveyp
  • 28 posts
Posted 11 July 2011 - 06:12 PM
Hi all , bit of progress on the mini blackbird. Too much real work getting in the way unfortunately but its definetly getting there.
pics of rear trailing arm assemblies, the lovely diff unit built from scratch and the power unit sitting in its (roughly) final position.
waiting on BB exhaust manifold and sprockets to arrive to get on with the next stage. think i am at upload limit for photos.
cheers DaveAttached File  IMG00025_20110711_1353.jpg   665.04K   46 downloadsAttached File  IMG00033_20110711_1356.jpg   964.31K   30 downloads_1356.jpg]Attached File  IMG00024_20110711_1352.jpg   646.62K   31 downloadsAttached File  IMG00034_20110711_1356.jpg   771.89K   39 downloads..711_1356.jpg]Attached File  IMG00027_20110711_1353.jpg   548.57K   17 downloadsAttached File  IMG00023_20110711_1352.jpg   676.44K   25 downloads0023...711_1352.jpg]Attached File  IMG00032_20110711_1355.jpg   875.8K   35 downloads[attachment=114579
:IMG00035...711_1357.jpg]
#9 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 15 July 2011 - 01:13 PM
Suggestion:
Consider adding the facility to alter the camber of the rear wheels. You can do this by allowing one of the bolts that are holding the rear swingarm (possibly prefer the inner bolts) to move up and down, with an adjuster. Just throwing it in the mix for you......
#10 daveyp
daveyp
  • 28 posts
Posted 16 July 2011 - 06:36 PM
Suggestion:
Hi captain,
we did consider camber adjustment for the rear wheels with a concentric adjuster built into inner part of rear arm, but it was going to be a lot of hassle and pretty inaccessible at the end of the day. So the swingarms have been made with 1.5 neg which is a pretty good place to be. Have found in the past that once you've adjusted once they never get touched again......
Dave
Edited by daveyp, 17 July 2011 - 07:51 PM.
#11 alowry
alowry
  • 94 posts
Posted 04 October 2011 - 09:57 PM
Hi Dave,
Great project. I've been building a Zcars blackbird mini, so if you've any questions surrounding the engine, electrics etc let me know if I can help. My cars mechanically finished & running more or less although i've yet to take it for a decent run. Are you planning on using a baffled sump, accsump etc to look after the engine?
Adam.
#12 daveyp
daveyp
  • 28 posts
Posted 08 October 2011 - 11:30 AM
Hi Adam,
My colleague Jim keeps banging on about the accusump going in as he's an autocross buggy racer and he swears by them, but I'm not so sure we need one as its mainly for road use. Do you have one on yours?
We were going to try and keep the electrics as seperate as possible, did you use bb clocks or a digi dash type unit?
Probably will have a few more questions soon!
You got any pictures of your project available?
cheers Dave
#13 daveyp
daveyp
  • 28 posts
Posted 08 October 2011 - 11:34 AM
Adam,
Just found your project in the z cars section, so ignore the photos request
Dave
#14 alowry
alowry
  • 94 posts
Posted 15 October 2011 - 09:11 PM
Hi Dave,
Bit slow replying as I'd forgotten I'd posted on your thread. I've no accusump but plan to use one especially as I've a shortened sump to fit. I've the bird clocks fitted at the moment but ill switch to something else eventually, just more simple to use the original clocks initially. I'll try & get a few more pics up soon as the cars driving now & I'm finishing the bodyword to send it to the paintshop.
Ask away here or on my thread if you've questions.
Adam.
#15 sayli
sayli
  • 35 posts
Posted 20 October 2011 - 05:16 AM
looks great, I'm getting a custom frame for my R1 mini.
