Mini Cbr-xx
daveyp
, Feb 22 2011 09:04 PM
28 replies to this topic
#16
Posted 17 December 2011 - 05:49 PM
Hi everybody, been thinking about a servo for the new brakes , how have you guys done it?
#17
Posted 21 December 2011 - 05:13 PM
Interesting build Dave !
My car also has a Blackbird engine, and did use a Power commander 3 to look after it all, Ive still got the full hiss system + key, ecu and engine loom - not sure if your carbs or efi.
Mine has got a bias pedal box, so will have the 2 brake cylinders and no servo. Not sure what brakes your going to use ?
#18
Posted 21 December 2011 - 05:22 PM
Had KAD bias pedalbox and no servo, car only weighed 460kg so not required!!
#19
Posted 22 December 2011 - 06:58 PM
Yes I was thinking it won't need a servo as hopefully it'll weigh around 500 kg. The brakes I'm planning on are willwood dynalite 4 pots with drilled/ grooved discs, what Lind of money is involved in a KAD bias pedal box? Sounds like a good idea, have emailed z cars about their big brake kit to see if they could machine the bells to fit ford pcd but never had a reply yet.
#20
Posted 22 December 2011 - 11:44 PM
A 500kg car doesnt need very big brakes. Mine runs Cortina front discs, Wilwood M16 calipers with Mintex 1144 pads. Grooved and drilled is up to you, Ive got 2 sets, and Ive just read an article recently , grooved and drilled on a small light car doesnt make a whole lot of difference.
OBP make good pedal boxes, avoid the cheap ones.
#21
Posted 23 December 2011 - 07:05 AM
That's good to know about you're set up t66, higher performance ford gear is a lot cheaper than the z cars mental prices.
On a blackbird note do you use the bike clocks or digi dash in yours?
Also what's your front sus set up as you're obviously running ford gear as well.
Thanks Dave
Thanks Dave
#22
Posted 17 August 2012 - 05:50 PM
Hi everybody, some good progress being made here. Just bought an accusump and valve etc so we can get the bracketry (is that a word?) all sorted before painting.
Cheers Dave
Cheers Dave
#23
Posted 17 August 2012 - 05:52 PM
Trying to do photos from ipad but doesnt seem to work or am i just being thick
#24
Posted 17 August 2012 - 06:08 PM
Your just thick HA HA
only joking me and tecky stuff dont get on either hence why my phone hasnt been turned on for atleast 3 years
#25
Posted 17 August 2012 - 07:04 PM
Think your right!
I'll have to go back to the old pc to get the photos up.
#26
Posted 18 August 2012 - 04:57 PM
Think I might have it cracked!
Please let me know if this works
Cheers Dave
Cheers Dave
#27
Posted 22 August 2012 - 04:53 PM
Hi, bit more progress.
Rear sus mounts, more cage work all just tacked at the minute. Should be doing final welding soon, then starting on front sub and suspension.
Cheers Dave
Cheers Dave
#28
Posted 22 August 2012 - 08:55 PM
Looking at having a digi dash type unit does anyone have any recommendations and just how compatible are they?
Cheers Dave
Cheers Dave
#29
Posted 26 August 2012 - 08:07 AM
Would anybody have any input for spring rates for mid mounted bike engined mini, wondering what others are using.
I have avo coilovers on the mini but they came from a westfield so i suspect the rates will be wrong for the mini. I know there are calculators on the web but just looking for a starting point.
Cheers Dave
Cheers Dave
