Condition: NEW
Price: £215 Posted (UK)
Optimum Braking Products
CLASSIC MINI ADJUSTABLE BRAKE BIAS HYDRAULIC CLUTCH TOP MOUNTED PEDAL BOX
Hi Gang, this pedal box was kindly donated to me by OBP to sell on to raise money for Macmillan Cancer Support.
Description taken from OBP:
This pedal box has been designed specifically for the Classic Mini we have worked very closely with a Mini specialist to create a hi-performance system that is easy to fit. We are confident that our Mini bias brake pedal box is by far the best solution available on the market.
This is a total replacement pedal box, not an add on part that does not work. We have tested and designed the 6:1 pedal ratio to give optimum pedal performance.
All our pedal boxes are manufactured in our UK based factory, this is how we can maintain the highest level of quality control.
The Mini pedal box is a light weight mild steel under-slung pedal box design, that offers the driver the highest level of efficiency in this critical area. The ergonomic design features a fabricated lightened steel brake and clutch pedal with oil impregnated spherical bushes that sets new standards in pedal box design. This pedal box is fitted with a bias bar that operates a dual master cylinder braking system, giving total control over the braking from front to rear.
Kit Contents: 1 x 3 Pedal Mini Pedal Box,
Please check our other items via our ebay shop or our fantastic web site obp.uk.net
Normally over £300
Charlie
This topic is locked
