my car is coming home tomorrow so im going to start on the body.
it needs filling just under the headlights and one of the scuttle corners.
Any tips on getting it good? getting it flat with the rest of the panel?
the bit under the headlights looks like it will be hard because it is butted up to what i think is a seam. and i don't want to fill the seams.
any advice appreciated.
thanks guys
mark
tip on filling...
screech
, Jan 07 2006 08:45 PM
6 replies to this topic
Posted 07 January 2006 - 08:45 PM
Posted 07 January 2006 - 09:22 PM
yes, take it to a body shop lol!
Posted 07 January 2006 - 10:22 PM
i am prepping it my self to save on the money! it cant be that hard to do a bit of filler! and a bit of primer.
Posted 08 January 2006 - 11:16 AM
Warm the body filler tin, as it makes the filler easier to apply,
what is it you are trying to fill ?
if it is minior blemishes get a filler primer, this goes on heavy and is easy to sand.
Halfords do it in a can if you done have a paint supplier in your area
Posted 08 January 2006 - 11:31 AM
its around the windscreen and headlights. just where it was surface rust and its got little bits that need a little filler.
Posted 11 January 2006 - 11:59 AM
Get a tin of top stop, this is a 2 part filler / stopper so wont shrink as filler primer will.
you can use the filler primer for taking care of any minor scratches etc left in the filled surfaces
Posted 12 January 2006 - 07:06 PM
I read somewhere that mixing the filler in one direction was the best was of mixing it because it stop too much air getting into the mix (like with clay, you have to throw it on the table to get air out of it otherwise you'll get pinholes ion it or even worse, the kiln would explode!)
