Busa Busa
#16
Posted 02 July 2011 - 11:57 AM
are you not supporting the rear of the engine? or is that yet to come. its looking great now!
#17
Posted 02 July 2011 - 01:00 PM
#18
Posted 02 July 2011 - 03:26 PM
#19
Posted 02 July 2011 - 03:31 PM
#20
Posted 02 July 2011 - 03:50 PM
#21
Posted 04 July 2011 - 09:07 AM
what would make you say that its free wheeling has to be same speed and is going to be fixed i had a sprocket centre drill out with sealed bearing in middle and seperate tentioner soon see if works lolhow will you make up the jockey sprocket? if its spring loaded to act as a chain tensioner, it could still hit the casing when the diff spins faster than the engine output shaft and puts all the tension on the lower side of the chain.
#22
Posted 04 July 2011 - 06:41 PM
however since you have said it will be a fixed sprocket then it should be fine, although you might want to mount it onto a slotted hole so that you can move it slightly to tension the chain accurately and allow for chain stretch over time.
#23
Posted 05 July 2011 - 08:42 AM
[/quote]
yeah you got it that was one idea i did think about as it would still be solidly fix but adjustable dont wish to give to much away lol want to see what works first ive found lots that dont but its all learning though the other was to make centre of sprocket like a cam {snail shell} but slot would be simple i like simple less to go wrong the big worry that i am concerned about is with the idea i have i will have to remove waterpump for the run of chain but this will allow me to put engine more over drive for better weight balance but by removing pump and blanking it off i will have to use electric pump which has its good and bad points was looking at FORD-FOCUS-RS-12V-WATER-PUMP- but still bit unsure
#24
Posted 20 July 2011 - 06:11 PM
Edited by miniblade81, 20 July 2011 - 06:11 PM.
#25
Posted 22 July 2011 - 10:51 AM
#26
Posted 31 July 2011 - 08:18 AM
#27
Posted 14 August 2011 - 06:35 AM
#28
Posted 04 January 2012 - 05:52 PM
#29
Posted 04 January 2012 - 07:02 PM
#30
Posted 07 January 2012 - 05:00 PM
