Does any one no how to remove a shell I know that you take the two subframe bolts at the front and back but what else?? :erm:
NEW SHELL??
minicruise
, Apr 28 2004 11:04 AM
7 replies to this topic
Posted 28 April 2004 - 11:04 AM
Posted 28 April 2004 - 12:43 PM
just take off everything else that connects to it.
Posted 28 April 2004 - 01:01 PM
oh ok :nugget:
Posted 28 April 2004 - 01:02 PM
depending where u start form, ususally the engine is a good start. remove this, probably followed by the interior(doesnt really matter what really) then i would sugest removing the front subframe and keep the hand brake on. then once the fron end is removed and the car is on axel stands i would jack the rear up and remove the 8 bolts. though i sould remove the pertol tank battery and so on first(just read about removing subframes in the haynes)
basically use a little common sense and a haynes manual and u cant go too wrong, if u need any more help just ask.
Posted 28 April 2004 - 02:00 PM
Remove the shell?
Try thinking of it the other way around – you have to remove all the oily bits such as the subframes and engine from the car to leave the shell!
:smartass:
:smartass:
Posted 28 April 2004 - 08:31 PM
You can make a nice trolley for your sheel out of some 3 x 2 and castors from screwfix :grin: :grin:
Posted 28 April 2004 - 08:33 PM
Oh by the way if you have any questions about strippin your shell just ask, i stripped mine quite recently so should be able to help you :cool:
Posted 29 April 2004 - 01:48 PM
I'll second what adam c just said. any questions just shout.
Al
Al
