Removing Camshaft With Engine In Situ 1275
15 replies to this topic
#1 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 27 May 2011 - 09:12 PM
quick question, is it possible to remove a camshaft from a 1275 A+, without taking the engine out and splitting the engine from the gearbox etc? ii know you can with a 998 as they have tappet chest covers, but is it at all possible to do it some how with a 1275. as i really cant be asked to remove the engine again. thanks.
#2 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 27 May 2011 - 09:15 PM
I've never tried to do this, so don't blame me if its goes wrong.........
Buy 8 of the small telescopic magnets, use them to hold each of the cam followers up whilst you remove the cam.
(it may work!!)
#3 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 27 May 2011 - 09:17 PM
thats exactly the way i was thinking of doing it sean a couple days ago, that must be the only way really i guess, cheers
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 May 2011 - 09:20 PM
Yes - just turn the car upsidedown.......... It has been done using 8 long magnet probes to hold up the cam followers - but one slip and you will at least need to take the speedo drive end off the box to recover the dropped follower, and no idea how you would then get it back in........ In any case - you need to at least carefully inspect the followers to see if they are suitable for re-use, and many recommend you should always fit new followers when changing cams, although I don't subscribe to that idea myself....... But they certainly must not have any pitting or crazing on the contact surface.
#5 MiniLuke
MiniLuke
  • 1,205 posts
Posted 27 May 2011 - 09:21 PM
But if you are changing the cam, don't you want to use new followers?
#6 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 27 May 2011 - 09:24 PM
Na the cam followers are fine, im putting the standard cam back inside it (hopefully) thanks for the quick reply, just need to buy some magnets lol.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 May 2011 - 09:26 PM
Hope it's not a spider drive oil pump..........
#8 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 27 May 2011 - 09:28 PM
nope, just a slot drive. wish i lived in australia then i wouldent need the magnets >_<
#9 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 27 May 2011 - 09:57 PM
That wouldn't work, think about it....
You may be upside down but you're also on the other side of gravity, this would counter-act the upside down-ness and you'd be back at square one.
Surely thats basic physics??!! :D
#10 Cooperman
  • 23,569 posts
Posted 27 May 2011 - 10:00 PM
Have to say it's not something I would fancy doing.
#11 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 May 2011 - 10:16 PM
Me neither - I couldn't stand the long journey to Australia.....
#12 rosstolley
rosstolley
  • 111 posts
Posted 29 March 2012 - 08:02 PM
I was just wondering about attempting this... Ill be following for the outcome.
Keep us posted on your findings Racer_Pete.
Cheers,
#13 MiniLuke
MiniLuke
  • 1,205 posts
Posted 29 March 2012 - 08:09 PM
You know that was about a year ago. Wonder if he went to aus?
#14 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 29 March 2012 - 08:31 PM
He did sell the car though!!
#15 rosstolley
rosstolley
  • 111 posts
Posted 29 March 2012 - 08:38 PM
Erm.. oh yeh! I'm a little bit late to be tagging on to this :D
