right i wnat to respray my mini completely when i get the bodywork sorted, preferably in two-pack paint, thing is is the original paintwork celly or not, its a 1986 city e
Also to complicate matters i want to put offset cobra stripes down the whole mini!
how would i go about doing this, or is it wise to get a professsional job done?
i am a poor student-cash is kinda tight could save 1200 in 4 months if lucky and lifeless!
some questions
mini-mad-dan
, Jan 25 2006 09:57 PM
7 replies to this topic
Posted 25 January 2006 - 09:57 PM
Posted 26 January 2006 - 10:07 AM
what i mean to say is can i just spray the stripes on the base coat or doi have to finsish the first coat then add detailing?
Posted 27 January 2006 - 09:21 PM
can anyone help me, i now know i can spray 2 pack over celly but what about the stripes, how much would this cost professionaly, assuming my bodyworks is spot on
Posted 28 January 2006 - 09:20 AM
Hey
The original paint on your car will not be celly, bit there is a chance that it would have been re-sprayed in celly, in any case you can spray 2 k paint over it.. but USE BREATHING EQUIPMENT... not worth you health for the sake of a spray job.
As for the stripes you can key the surface lightly, mask up with fine line masking tape and then paint, or for a simple solution get vinyl lines cut, easy to apply and
quick also. If you change your mind you can remove them at a later stage.
Posted 28 January 2006 - 10:38 PM
vinyl is an idea, i suppose if that looks good then i could spray them on, later, save a mistake!
Thanks will use the equipment, i think i know someone with some!
would a NBC suit be suitibele!
NBC=Nuclear, Biological,Chemical protection, don't ask how i can get one of those! :tongue:
Posted 29 January 2006 - 06:47 AM
Lol I've got a few of those but don't fancy painting in them, after a hour in them it gets pretty uncomfortable you have to wear a layer underneath them otherwise the charcoal will comes off as you sweat, a one piece light weight painters suit is fine.
Posted 01 February 2006 - 08:55 AM
As above suit will be a bit of overkill....
spray suits are cheap... a fiver.....
click below
Disposable chemical spray suit.. 5 quid
click below
Posted 05 February 2006 - 11:42 AM
is definatly overkill, because im going cellulose, for the time being, then having it repsrayed professionaly in 2pack, once i have saved enough, any important considerations i should consider for celly?
