Fuel Problems I Think
23 replies to this topic
#16 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 19 September 2011 - 03:50 PM
Thanks to all for your advice on the fuel problem and the egg collector can get back to sucking eggs Cheers
Looks like I might have rubbed you up the wrong way - didnt mean to - Sorry.
I hope the new pump is the answer to the problem - keep us posted.
#17 edsmini
edsmini
  • 357 posts
Posted 21 September 2011 - 08:50 PM
whats happening now? is the pump coming via rickshaw from japan :lol: im keen to hear the outcome :tumble:
Ed
#18 motorsorter
motorsorter
  • 25 posts
Posted 29 September 2011 - 07:06 PM
Hi all mini fixed, On z cars advice I dumped the old busa system and fitted a bosch pump and a regulator from z cars cars going great now .Thanks for all the advice
#19 edsmini
edsmini
  • 357 posts
Posted 29 September 2011 - 07:19 PM
how much does that setup cost?
glad that has fixed your problem mate :-)
Ed
#20 motorsorter
motorsorter
  • 25 posts
Posted 29 September 2011 - 08:15 PM
Hi Ed the regulator was £90 posted from z cars and I had a pump in stock The bosch pumps are about the £90 mark as well I think cheers
#21 cptkirk
cptkirk
  • 1,799 posts
Posted 30 September 2011 - 10:20 AM
Motorsorter, what pressure is the regulator set to? Curious for future project....
Glad to hear its all sorted...
Edited by cptkirk, 30 September 2011 - 10:21 AM.
#22 motorsorter
motorsorter
  • 25 posts
Posted 30 September 2011 - 11:39 AM
Hi The pressure is sitting at a steady 42 psi out of the box the cars running mint at that cheers
#23 sayli
sayli
  • 35 posts
Posted 02 November 2011 - 04:51 AM
I was not able to detact error. I simply moved the original pump back to the engine to its original position and installed electric
#24 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 13 May 2013 - 10:00 PM
First of all the z cars tank design isn't the best as I felt it needed a collector sump so it wouldn't suffer from fuel starvation round bends as much plus as I learnt running the fuel lines close to the coolant pipes isn't a good idea either especially in warm weather or traffic jams!!
It really needs a fuel swirl pot fed by s low pressure pump circulating fuel so it gets a constant supply an keep the lines away from heat sources as much as possible.
Hope you got it sorted?
