10 Inch Steels Over 8.4Inch Brakes
#31
Posted 08 September 2011 - 09:52 PM
Still not sure why spacers are such a problem, especially if you're fitting them to a Mini that's already had the mods for heavy 13s.
#32
Posted 08 September 2011 - 10:09 PM
But that's just me.
#33
Posted 08 September 2011 - 10:40 PM
(But teenies - how much they weigh? 6/7kgs with the tyres?)
#34
Posted 09 September 2011 - 06:45 AM
I'd rather be satisfied with the work I've done and pay the money for a brake setup which isnt grinded instead of doing a bodge!
But that's just me.
I totally agree. I cannot seem to edit my post (#27), but this was referring to the 10's with the built in spacer as per Mini Magic's old mini; not weller's with a grinded caliper. I would not want to be grinding my calipers.
#35
Posted 09 September 2011 - 09:11 AM
Draw an imaginary line through the top and bottom ball-joints and project it downwards. On most cars it will hit the ground around the centre of the tyre's contact patch. This means that when you turn the wheel it is spinning about it's centre on that pivot point and the resistance is as small as possible. With 13x7 or 13x8 or whatever size wheels you try to keep this situation the same. OK with a wider wheel you add a little resistance either side of the centre-line and up the stress on the components but not by a huge amount as you are still simply spinning the tyre about that contact patch.
Now add a 1" spacer. That moves the entire contact patch 1" further out from that pivot point. THAT is what puts all the stress on the components. The tyre is now turning about a point almost on it's edge. In order to turn one way or another the whole thing has to move forwards or backwards as well as scrubbing sideways. So you're thinking that moving forwards or backwards is easy for a round thing? Try it with 30 horsepower trying to push it the opposite direction - or has your Mini got more power than that? (yes really it's the ft/lbs that matter here but most people think in terms of horsepower so for simplicity of the example I used the wrong term).
Iain
#36
Posted 09 September 2011 - 07:36 PM
But i can understand and feel the extra stresses put on the suspension components.. however the next will have to be wider similar wheels put over smaller brakes ... with a less excessive offset.
Edited by jimmyH, 09 September 2011 - 07:41 PM.
#37
Posted 10 September 2011 - 11:25 AM
No spacers or built in, just a massive offset, right over my MPI 8.4's. They pull around abit on the hills, but look pretty good i think ..... oh and hold the road damn well too ...
Are they the newer alloy version?
#38
Posted 10 September 2011 - 11:55 AM
#39
Posted 10 September 2011 - 12:24 PM
#40
Posted 10 September 2011 - 02:05 PM
Because the Cooper S brakes cost £300+ and is a lot more work then just fitting a new set of wheels.
Wrong....
http://www.minispares.com/Product.aspx?ty=pb&pid=42536&title=
and with a TMF+ discount brings a lot closer to £200
#41
Posted 10 September 2011 - 02:22 PM
#42
Posted 03 October 2013 - 01:30 PM
Wrong....
http://www.minispare...id=42536&title=
#43
Posted 03 October 2013 - 01:32 PM
