So Santa came early today......delivered this little lot.......
Firstly this came......
New parts -2/06/2011 by Andrew Forbes Photography, on Flickr
can you tell what it is yet?
Of course you can! Its a set of lowered ride height adjustable GAZ shocks! Always wanted a set so.....I got them
They are TUV approved and are individually tested to manufacturers specifications at the factory. Even got print outs of the dyno run for each shock in the box. 2 year warranty too.
So alongside these I got a few other bits.........
- Heritage Scuttle panel (excess holes will be welded up for a smoother look)
- Headlamp bowls (including inner rings etc)
- Front indicator to body seals
- Original specification wiring loom (which shall be modified to accommodate my triple clocks in the centre of my dash which are clock, oil pressure and voltmeter)
- CV joint boot replacement kit (both sides)
- Driveshaft seal kit (both sides)
- Manifold gasket (at the great expense of 88p!)
- Paddy Hopkirk throttle pedal
The throttle pedal...which shall have a custom twist to it soon to be revealed....
So Im affa happy and that SHOULD be most of the big bits ordered and here now....so its just over to Fastmini1380 now asap to get it welded.......then its off to paint!
