Stumped!
#16
Posted 05 February 2012 - 03:39 PM
Ivan
#17
Posted 05 February 2012 - 03:42 PM
#18
Posted 05 February 2012 - 05:22 PM
ignition been isolated from the ecu by running a distributor... so kinda rules that side of things out..
would suggest its going lean when the throttle is being closed.... air leak???
personally though I would confirm the idle setting on the stepper...
#19
Posted 05 February 2012 - 11:36 PM
#20
Posted 27 June 2012 - 09:50 PM
#21
Posted 27 June 2012 - 10:24 PM
#22
Posted 09 July 2012 - 06:24 PM
#23
Posted 20 July 2012 - 08:48 PM
#24
Posted 23 July 2014 - 08:08 AM
#25
Posted 24 July 2014 - 07:14 PM
Yes indeed it's been a while. had been reading this thread quite at the beginning. Its nice to hear you finally got things sorted and the mini is running fine now. Quite strange though that all the auto electricians you visited were not able to find the problem. And even stranger is can't really figure out why it would only die when letting off the throttle if it's a ground issue?
#26
Posted 24 July 2014 - 07:39 PM
#27
Posted 24 July 2014 - 08:11 PM
Yes i quite understood what your problem was, but what i don't really get is how the ground affects this, and why only when letting off the throttle and not an other time? Could it somehow be due to the engine movement when letting off the throttle which was giving a bad ground for some reason? Well Have a great trip then, sound nice! And hope all will go well
#28
Posted 24 July 2014 - 09:43 PM
#29
Posted 11 August 2014 - 08:33 PM
#30
Posted 25 May 2017 - 01:30 PM
