So, a summed up bit of the last week or two:
Got the rear subby off (again)
Repaired the snapped stud. Seen a few ways to do it but made a stud M8 to M10. I know i know, metric and all that.
M8 was to go into the snapped stud on the subframe. Did this by machining a jig to locate the drill dead centre (5mm) then drilled out to 6.9 to tap to M8.
Worked well in my opinion, although not the full repair i've seen some do with a whole new plate and machined stud all welded in.
Then stuck it in the shot blaster and its getting powdercoated as well speak/as i type?
anyway, overhauling the radius arms while i wait and got another order in with minispares for the poly mounts etc.
Edited by chrisn89, 09 June 2016 - 05:15 PM.
