Having Problems With Spi Single Point Injection
145 replies to this topic
#136 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 26 September 2016 - 01:41 PM
Can anyone tell me where the MAP sensor is on an SPI (95) please?
My engine runs perfectly with the exception of a 1/2 second hesitation when you floor the accelorator (either driving or standing).  I've had a few tips to check the MAP sensor, but can't find it!!
It's in the Ecu, connected to the inlet manifold via a black vacuum pipe with a fuel trap in the middle. The plastic elbows on these can split and cause air leaks and running issues. Also check the red vacuum line to the air box, and the yellow line on the airbox for splits
#137 Maundrell
Maundrell
    Starting My Mini Up
  • 4 posts
Posted 07 December 2016 - 10:51 PM
Coolest temp sensor in Inlet Manifold - Can it be reached for under th car????
I need to change my sensor, but after looking at it can't get access to the sensor from above and don't have a jack large enough to get under the car to see if it's possible to get acces from there. I don't fancy removing the inlet manifold so looking for an easy solution.
Any tips??
#138 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 08 December 2016 - 07:56 AM
Easiest solution is to remove the inlet manifold...
Had to do it to mine a while back and tried all sorts of ways, easiest way is to stripdown the inlet manifold.....
#139 hungdynasty
hungdynasty
  • 161 posts
Posted 08 December 2016 - 02:09 PM
Any tips??
Yes, I did it under the car, but room is very little, if you have big arms and hands you will find it very difficult.
#140 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 29 December 2016 - 04:29 PM
I did it once from under the car - it is a pain in the a...
Easier to remove manifold and at the same time clean what ever needs cleaning.
Edited by Alpenflitzer, 29 December 2016 - 04:30 PM.
#141 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 29 December 2016 - 05:06 PM
Any tips??
Try driving it so you have one wheel on the footpath and one wheel on the road. This will increase the clearance quite significantly, abroad this method has helped me out of problems several times.
Once when I broke down in France the only way to work underneath my car was to remove a drain cover and stand in it while the car was pushed over me.
#142 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 02 July 2017 - 01:44 PM
Maybe the CTS is defect or the cables/connections  are not okay. The CTS signals to the ECU and this one gives siognals to the injection.
Are you sure that your vac hoses are all ok? The original ones or silicone?
What do you mean by "the sensor reads low"? How do you read the sensors signals?
#143 MiniAida
MiniAida
  • 75 posts
  • Local Club: None
Posted 10 July 2017 - 11:30 AM
Hi Mininerd
I'm pretty sure the ECU and temperature gauge are linked i.e. if your (dashboard) temp gauge is reading low, the ECU will think the engine is cold & overfuel.
Flushing / cleaning the coolant pipe is a good idea, but I'm not sure if it will sort it as you will have loosened any gunk around the old sensor when you removed the old one. It's fairly easy, so give it a go anyway - make sure the rubber tubes are clear either end too as I've had lots of stuff collect in these, particularly near the heater valve.
My money's on a faulty sensor and / or connection fault on the sensor. I did exactly the same as you after a rebuild (changed all the sensors) which meant I didn't know which one was causing the problem & took a long time to discover. It did turn out to be the CTS, & not particularly expensive over here (£12)
Have you definitely used the (black) sensor?
The other point to note is that the old the MEMS modules can reset to default if disconnected from the battery, so will have to "relearn" the engine's best settings which can take some time.
*Note* do check the 195 deg thermostat is the correct one for Canada spec, as it will not help to have it opening at the wrong temperature. by the way getting cooler when driving "logs show it sees 70C or better until you start driving" suggests the old thermostat might be sticking open.
It took me (and the local mini specialist) several weeks and almost a full a tank of petrol to sort this out, but we did get there - so don't give up!
I do think the temperature gauge is a clue though!!!
Good luck.
MA
#144 Keeef
Keeef
  • 10 posts
  • Local Club: Abingdon Mini Owners
Posted 10 July 2017 - 12:02 PM
I had to bypass the heated manifold when on tour to IMM in Italy. Dash Temp gauge read normal but I have never used so much fuel in one day! I had to improvise a flow and return.
There is a sensor in the manifold which the ecu addresses. GTR307 (was gtr185) black plastic socket located in the underside of the inlet manifold.
That said if your running cool generally and can see it on your dash gauge both pickups will be affected and the ecu will over-fuel based on the manifold sensor response.
#145 Sprok
Sprok
  • 135 posts
Posted 12 July 2017 - 07:36 AM
Really good thread
#146 FlyingScot
FlyingScot
  • 2,660 posts
Posted 31 August 2017 - 10:10 PM
Okay there is lots of useful information in this thread which was the main reason it was pinned.
However it has become cluttered with individual issues needing a resolution which should be new posts to share the the information.
It is therefore locked.
If you want to add something to this please contact the admin/mods.
Big thank you to Sprocket who has done all the "heavy lifting" on this
If you have an issue post a new thread - the members/docs will help you.
FS
Edited by FlyingScot, 31 August 2017 - 10:21 PM.
    Google (1)
