R1 Wiring
Posted 20 October 2011 - 03:33 PM
And also if anyone has one or know someone who has one- I need the connector that plugs into the back of the clocks on a 2002-2003 5PW. The one on the wiring loom that came with my engine was busted and would like to replace it to keep all the wiring clean. I've called about 20 breakers and no one has one.
Posted 20 October 2011 - 07:16 PM
As for the connector try a Yamaha dealer. If not send me a picture of it and I will see if I can find you a part number for the connector(I do this a lot for my job)
Posted 21 October 2011 - 10:36 AM
Posted 21 October 2011 - 01:33 PM
Posted 21 October 2011 - 01:42 PM
best I could do with what I have. Order the samples as they are normally free and see if they fit.
Posted 22 October 2011 - 01:02 AM
Really appreciate all the help
Zach
Posted 22 October 2011 - 07:35 PM
I'm using the 02/03 R6 clocks which are the same except for the tacho scale. Got my R1 harness off eBay but they don't come up often and can be expensive. As far as I'm aware you can mix and match the harness and clocks for either the R1 or 6 of the same year.
Can't quite grasp wiring it into the minis ignition though so progress on it has ground to a holt.
Try the guys at Yorkshire engine supplies. He got me clocks and partial harness among other bits I was missing off the original engine
Edited by racerlike, 22 October 2011 - 07:35 PM.
Posted 22 October 2011 - 09:10 PM
Are you using a push button or just turn the key to start it? Let me know. I can help you out either way.
Posted 23 October 2011 - 12:22 AM
Edited by ZKruly87, 23 October 2011 - 12:23 AM.
Posted 23 October 2011 - 07:52 AM
I'm using the key start ignition - My old wiring was a mess so I had a new one made up by Autosparks based on a MKIV loom. Three wires from the ignition - live, cranking and earth.
Managed to wire everything else up ok it's just integrating the clocks into the mini loom. I know which wire is which leading into the clocks as I have a diagram so it should be obvious....
Posted 24 October 2011 - 10:28 AM
Posted 24 October 2011 - 04:20 PM
Posted 24 October 2011 - 06:08 PM
I made life easy for myself and had Phil at pro-mo prep my loom for me.....so much easier !....and then John from COVICS did the final connections.
I'd have been totally lost otherwise >.<
Posted 18 December 2014 - 10:42 PM
my loom supplied with the Engine has an 8 bin Blue Connector (cable colour brown, red/white, green/yellow, blue and black,black,red, black), what is that connector for and where do the cables go. My electric plan of the 5pw shows only a blue 6 pin connector, cable colors don't fit.
Also the red 4-pin connectors the cable color doesn't fit, I have blue/red, black, blue, blue/yellow. What is the connector for and where do the cable go?
Thank you
Edited by Helldriver, 18 December 2014 - 10:43 PM.
Posted 19 December 2014 - 09:38 PM
http://www.robcollin.../electrics.html
