Intergrips Making Your Own
5 replies to this topic
#1 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 26 October 2011 - 05:43 PM
Hiya has anyone on here made there own or have a any decent pics or diagrams so i can make some
Danny
#2 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 26 October 2011 - 05:48 PM
I'm sure intergrips are like 12 pounds for 5?... pretty cheap.
Might aswell buy some.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,043 posts
Posted 26 October 2011 - 06:04 PM
I have made about ten and are pretty easy to make, I used pieces around the garage that I had. I have not got any pictures of them but I will get some up tomorrow.
There is a diagram on here www.mig-welding.co.uk
#4 coopdog
coopdog
  • 4,506 posts
Posted 26 October 2011 - 06:21 PM
what are they? haha
#5 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 26 October 2011 - 06:31 PM
what are they? haha
they're for holding two pieces of sheet metal together while welding
Really usefull!
#6 alex-95
alex-95
  • 6,043 posts
Posted 27 October 2011 - 05:32 PM
How to make:
Cut a slit down the centre of a 25x25mm box section with a 1.5mm cutting disk
Measure 2cm lengths
Cut the box section and then mark centre for a hole
Drill a 6.5 mm hole in the centre
Then Drill at an angle inline with the slot, so the bolt can be inserted
Cut a groove in a bolt for the metal to slot in
mark out a 20mm wide by 25mm long on a piece of metal
chop off the bolt head and cut metal
Put the metal in the slot then weld together
file the bolt and drill a 6.5mm hole in the metal for the round bar to slot in
Cut 6mm round bar or a bolt about 2cm long
Fix together
Dont weld the round bar like on the welding forum as you need to be able to remove them.
Alex
Edited by alex-95, 27 October 2011 - 05:37 PM.
