Bulkhead Sealing?
Posted 15 December 2011 - 08:28 PM
Greg
Posted 16 December 2011 - 12:35 AM
Posted 21 December 2011 - 09:50 PM
Posted 22 December 2011 - 02:21 PM
Ed
Posted 02 January 2012 - 09:03 AM
I am also worrying about access to the engine - easy now with no windows but any removable panels will have to come out over high backed seats and through the doors which might not be easy.
Greg
Posted 02 January 2012 - 02:22 PM
In my experience you will need to remove the seats to get access to the bolts that hold the firewall together, so maybe think about a quick release yet secure way to fix your seats.
Sorry I cant help much with the vertical firewall as I went with a parcel shelf but good luck with it.
Posted 02 January 2012 - 10:14 PM
Posted 03 January 2012 - 12:27 PM
Greg
Suggestion: make your windows easy to remove, mine are Lexan and bolted in using security bolts, I can gain access to my engine from the rear window and remove the parcel shelf in about 2mins and it takes me 2mins to put it all back together again, no working over seats or sliding bulkheads through very tight spaces and the majority of engine servicing can be done from that position. I also have the quarter lights bolted in and they are even quicker to remove to gain even more access to the engine bay. If I need full access to the front of the engine then yes I have to take the seats out but they are only 6 bolts each and their out, front bulkhead off and then I have unrestricted access to the engine. I didnt go with Lexan for weight saving it was purely for ease of access to engine bay, which is what it appears is your concern also. The first page of my build has pictures showing the lugs I had welded around the window apetures, they are simply a lug with an M6 thread in them, nothing more fancy than that, although if you've done your paint already you probably wont want to be welding to your bodyshell.
I am not saying its the only way its more food for thought......
Posted 04 January 2012 - 04:33 AM
Posted 08 January 2012 - 09:17 PM
Greg
Posted 09 January 2012 - 08:32 AM
It sounds like Alburglars way of fixing might be the best option for yourself, if you use rivnuts make sure to paint the hole before fixing the rivnut.
WE look forward to seeing how you end up doing it, as I am sure other future Zcar builders would like to also.
Andy
Posted 09 January 2012 - 09:56 PM
Not that I will be fitting windows for a long time yet but I wondered whether you had any type of gasket with the lexan windows or just bolt to the lugs with lexan directly contacting the metal - I had a look at your pictures but was not sure.
Thanks Greg
Posted 09 January 2012 - 11:59 PM
Posted 10 January 2012 - 08:23 AM
