Bringing out scratches
#16
Posted 11 February 2006 - 10:24 PM
#17
Posted 11 February 2006 - 10:41 PM
Try it now..should work
http://www.homebase....roductId=239718
(1).Theres 1 synthetic wool bonnet, 1 cotton bonnet. What does what? and which one do i use.
(2).So i apply the G4, then buff it with the Car Polisher, when i use car wax, shall i buff it with the car polisher as well ?
(3) Which polish shall i get ?
Posted 11 February 2006 - 10:59 PM
Do one panel at a time, and polish off using the wool bonnet.
While you're out, go and get another wool bonnet for the polish (Halfrauds do them). Apply the polish by hand, and buff off using the other wool bonnet. Then go over and make sure you've buffed properly by hand.
If you're going to Halfrauds for Polish, then get the best Meguiars you're willing to pay for (Gold class or NXT), or Autoglym. If you are willing to mailorder, get a sample size of Zymol or Swissol. They should be enough to do the car a couple of times (but they are VERY expensive!)
Oh, and Halfords do a very natty blue bottle of Zymol cleaner/polish. DON'T be tempted to use that as a top coat of wax, but you could use it between the compound and wax stages if you're feeling flush!
#19
As if you get any of the compound on these parts it will stain the badly (the same colour as you paint work)
#20
Posted 12 February 2006 - 01:28 AM
Zymol,
Meguiars Gold class,
But cant find Farecla G3 compound. couldnt find it on halfords site.
Can someone please give me a link to where i can buy Farecla G3 please. AND HOW much would i need
Posted 12 February 2006 - 02:21 AM
I *think* this is the stuff. I've not used Farecla, so I don't want to push you for this one. They do the whole range here anyhow. Karl can probably better point you to the right one.
What Zymol did you order? The cleaner stuff? Remember to get extra wool pads, you'll need them with the compound, cleaner and waxing to do!
#22
Posted 12 February 2006 - 01:14 PM
Use loads of water with this stuff and not too much pressure as you could burn, or go straight through the paint.
also here is a link for a pro style buffer, key thing in there is the rpm buffing about 1000 rpm max
so a grinder with a pad is a no no
clicky for buffer £45
cheers
#23
Posted 12 February 2006 - 02:09 PM
Farecla
I got this Zymol ?
http://www.halfords....ategoryId=31511 ?
Which G3 should i buy ?
Thats the stuff G3..
cheers
I already brought this http://www.homebase....ategoryId=37484
So why would i need this as well http://cgi.ebay.co.u...bayphotohosting
Then someone near my way said i need a G mop pad like this http://www.paints4u....?productID=2499
Im well confussed now... confused.com lol
Someone lighten me up please ..
#24
Posted 12 February 2006 - 07:18 PM
As for the buffers, well, you don't need both. one will do, and if you've ordered the homebase one..... The other one is a bit more "pro". it will probably allow you to vary speeds and the pressure that you put on the paint, but I've had no issues at all using one that you've ordered.
The pad you have linked to is effectively a sponge pad. It has a certain density which will mean it has certain abrasive properties (to work in conjunction with the G3) and allow the pad to retain a bit of moisture. Basically it goes with the more "pro" idea of the mop buffer that Karl linked from ebay. I've never found a problem using a cotton bonnet on the orbital polisher AS LONG AS YOU KEEP IT WET! Whatever you do, DON'T buy that G3 pad and put it on a grinder. It will fit, but the speed of the grinder will be WAAAAAAAY too high, and I guarantee you will burn the paint!
Also, when you're doing this, take it slowly. Use light pressure on the polisher. If you have to do it again, then so be it. I'd rather go over it 3 times than do it once by pressing a bit harder and end up burning the paint.
#25
Posted 13 February 2006 - 12:10 AM
How many more wool bonnet's shall i buy. ?
Will i need THE Regular Grade G3 Paste Compound with- (400gm) or more ?
Shall i cover the windows as well.. not gonna start it till im 100% sure i know what im doing lol
Thanks matey..
#26
Posted 13 February 2006 - 01:22 AM
You'll need as many bonnets as you use treatments (one for compound, one for wax, etc)
400g should cover a mini comfortably, even assuming you give it a couple of goes.
No need to cover the windows, they'll just hose/wash down afterwards. same with the bumpers. It's the rubber seals you need to be careful of because they won't wash down easily without staining.
#27
Posted 13 February 2006 - 10:32 PM
Just give it a quick wipe down with a clean rag afterwards, and use the wool bonnet dry. put the cleaner/wax and the wax on by hand, and off with a dry, clean wool bonnet.
So can i use one bonnet for the compounding ? then say 1 wool for cleaner wax, and then one for top wax .
Anyway, thanks for all your help thou.. wish me luck
#28
Posted 13 February 2006 - 11:01 PM
Good luck
#29
Posted 14 February 2006 - 01:09 PM
Shall i send it back to be replaced ?
Ill add a pic later when im home..
#30
Posted 14 February 2006 - 04:54 PM
Couldnt get any wool bonnet from halfords, havnt got any.. was a right sh*t halfords..
Do you know anyother place.. thanks
