how can I get 10s on my mini I've tried one of my mates and they catch on the calipers so how can I get them to fit someone told me I could grind down the calipers any advice
wheels
pierce
, May 11 2004 08:25 PM
2 replies to this topic
Posted 11 May 2004 - 08:25 PM
Posted 11 May 2004 - 09:39 PM
Hi, to fit 10s on you need to buy some cooper 's' calipers, or some minisport 4 pots, which ever option you go for you are looking at around £200 at least just for the calipers!!
Wouldn't advise grinding the caliper, as if the casing cracks you can say byebye to your breaks, and maybe your mini!
getting the discs is simple, as you can just get some off a metro and get them machined down
Rich.
Rich.
Posted 11 May 2004 - 09:50 PM
If you fit S calipers you also need the correct S discs (you can't machine the 8.4s down to 7 inch)
With the alloy 4 pots you can machine down the 8.4s to 7.8 inch to suit.
Don't bother with metro discs.
Also with the 4 pots you need to be carfull which wheels you are going to use. some 10s will not fit, ie 6x10 Mambas will not.
Siggy
Siggy
