Hello Doc's.....
and nurses of course :cheese:
I have a running problem with my baby.
0 - 50mph she seems fine but hit 50/60mph then some times she will cough and splutter and some sort of power loss, Not stalling or anything she still trys . sounds like she has a cold with the coughing and splutering.
She seems fine round town and stuff but when I hit the A380, plenty of hills that make your ears pop, thats when she goes.
Advice needed please ASAP as I have to drive home.
Tucker
Doc... I need an appointment for my baby
Tucker SP
, May 12 2004 07:02 AM
12 replies to this topic
Posted 12 May 2004 - 07:02 AM
Posted 12 May 2004 - 11:30 AM
bump :gasp:
Posted 12 May 2004 - 12:02 PM
my last mini used to do that, only when it rained tho
Posted 12 May 2004 - 06:25 PM
what do you mean by "BUMP" ?bump :gasp:
Posted 12 May 2004 - 07:53 PM
ya mine does that at the mo,
0 to 30mits ok then the car starts jerken and going pop etc... its the fuel mix, i thinks
well all i need is a rolling tune,
sound like thats what you might need.. :fear:
Posted 13 May 2004 - 06:54 AM
Woody,
just to make the post back to the top of the page. :cheese:
Seems strange, only seems to happen on certain roads.
Fuel mix....hum not long had that set up, she was running rich, the guy did say that there was a bit of unburnt fuel going through. On idle you can here a pop, like she's missing a bit.
The pop has always been there on idle ever since I have had her, but been on the same roads before and not had a problem.
I was going along today on one of the trouble roads and I see a same plate mini in front but could not catch it up due to this prob. It done me and the wife said, THAT MINI'S ALL RIGHT. Hugh... I said that might have a bigger engine Could not see it any more and I was left behind, hit the M5 though and I caught up with it, with no running props at all, How do people cope with hill climbs??
It must just be a poorly Doris.
Tucker
Tucker
Posted 13 May 2004 - 05:33 PM
Hi Tucker.
I was talking to a customer today about Minis in general and he was telling me about a very similar problem. The car ran fine until it got to a decent hill, then would cough and splutter with a significant power loss. Turned out to be a slightly leaking exhaust joint allowing hot gases to heat up the fuel pipe and cause fuel vapourisation. It only manifested itself on hills because of the extra load on the engine.
Cheers,
Nick
Cheers,
Nick
Posted 14 May 2004 - 06:48 AM
I will tell you what Badger... I would of never thought of that :erm:
Done the same thing today, and i was just about to put it down to them hills, she loves hitting the M5 tho
Looks like I might have to treat my self to a new zorst :cheese:
Im going to pop to a mini place today and see what they can come up with.
Tucker
Oh....mini place is:
Tupman's Minis
01626 368828
Clifford Street
Kingsteignton
Newton Abbot
Devon
TQ12 3HD
:cheese:
Tucker
Tupman's Minis
01626 368828
Clifford Street
Kingsteignton
Newton Abbot
Devon
TQ12 3HD
:cheese:
Posted 18 May 2004 - 06:44 AM
Hi People,
I went in to Tupman's on friday....not much cop, he just said it would be best to wack her on the rolling road and that you could change a number of parts and it still not make a differance
I dont think that would help as it only happens on the A380, OK on all the other roads. It happens down hill as well so the enging is not under load.
I lifted the bonnet on her and had a look for any zorst leaks, could not find any. I did notice some sort of fuel filter resting on the manifold tho, took that off of it and tucked it away and still no joy.
Help needed as big arse lorries are sitting up me arse and they cant tell Im slowing down.
Oh....that bloody mini done me again today. (some old bird)
Help please
Tucker
Help please
Tucker
Posted 18 May 2004 - 10:01 PM
Sounds like a similar problem I had with my City. Would be ok and fine on motorways but any good change of incline used to make it shudder badly and slow down. I just replaced all the ignition leads, plugs, cap, rotor arm, points, condensor and coil. Then set the dwell angle and timing + fiddled with the mixture control and its running ok now, not perfect but only a rolling road will cure it completely.
Posted 19 May 2004 - 06:55 AM
Cheers papa,
Its had new pionts, dizzy cap, rota arm and condensor
Its doing it most of the time now, its sort of the same simptons it had when the feul pump was lose. run fine, then cough and spultter and cut out. Its doing that now but most of the time on any road.
It cut out on me today and had to pull on to the hard shoulder (twice), I checked the nuts and they was tight. do ya think it could be a faulty fuel pump?
cheers
Tucker
cheers
Tucker
Posted 20 May 2004 - 06:57 AM
On the way home last night it did it again
Had some tools on me this time took off the air filter and opened up the flot chamber guess what..... she was empty
What you think???
A f**ked fuel pump??
If so I will order one today but which one shall I get??
Tucker
What you think???
Tucker
Posted 20 May 2004 - 11:47 AM
What you think people?
