just had it out for first time fully legal (only other trip was to MOT station) and getting a hell of a lot of road noise from the passenger air vent. This common n how do i cure?
Air vents
rob mini
, May 12 2004 08:29 PM
4 replies to this topic
Posted 12 May 2004 - 08:29 PM
Posted 13 May 2004 - 07:32 AM
Try closing the vent...
Posted 13 May 2004 - 11:48 AM
The pipe for it runs up under the wing - perhaps its catching on summit or just loose and vibrating a lot?
Posted 13 May 2004 - 05:17 PM
if its a vibrating noise check the bonnet hinge, it was drivin me crazy for weeks until i discovered what it was, as i sounds so close to you and in the car but its just a loose nut, give it a try matey
Posted 13 May 2004 - 05:18 PM
or if its round noise there should be some foam inside the pipe tube that deadens the noise check to see if u have some, it should line the inside of the pipe
