Head Gasket Cost?
#16
Posted 19 January 2012 - 06:50 PM
right, what exactly tools wise do i need to this job myself, i think im going to give it go
#17
Yeah as Dan says, half a days job at the most and it means you can put everything back how it should without it being damages by a garage rushing the job :)
AND it is alot cheaper.
and you get the satifaction fromt doing it yourself to
#18
Posted 19 January 2012 - 06:53 PM
i do indeed,
11mm 13mm 14mm and 15mm sockets torque wrench few spanners
danny
#19
Posted 19 January 2012 - 06:55 PM
Exactly! keeps you busy and you gain experience from it too!
if you do do it yourself, just make sure that all mating surfaces like the head are spotless and clean so that the gasket can seal well...
Also, I would clean the cylinders out too whilst you have the head off.
A tip that I did was to smear greace around the inside of the bores so that any crap falling down to the cylinders wont get caught and scratch the block.
Just then make sure to clean all the greace off.
They are fairly easy to clean up too!
Cleaned them 2 at a time! came up well for 1983 cylinders :)
Have fun!
#20
Posted 19 January 2012 - 07:15 PM
#21
Posted 19 January 2012 - 07:16 PM
#22
Posted 19 January 2012 - 07:18 PM
I used to do this 2 or 3 times to ensure the head it torqued down nice and even, it is suprising how much the torque values will vary from one bolt to another after being ran up.
Failure to do so will result in premature gasket failure, trust me it is rather frustrating changing a gasket you only replaced a month ago.
#23
Posted 19 January 2012 - 07:20 PM
Just make sure that after fitting the gasket that you re torque the head down..
i can vouch they i had to replace mine 2 weeks after because i had a water leak and it boiled over was because of torque but was still a pain in the ass !!
#24
Posted 19 January 2012 - 07:31 PM
Before you torque the head down, slacken off all the tappets wind the adjuster screws out . The pressure of the valve springs could give false torque readings, now this may be hogwash but it takes 5 minutes so doesn't hurt :)
And actually the socket sizes will all be imperial not metric as mentioned, although those metric sizes will be about right.
7/16"
1/2 "
9/16"
5/8"
#25
Posted 19 January 2012 - 07:41 PM
Matt
#26
When i had to replace my head gasket i did the water pump + bypass while i was there because i didnt know their age (could have been on there years and years before i got the car) and its an easy job without the head on.
#27
Posted 19 January 2012 - 07:47 PM
But this means the car being off the road longer and if you havn't done that thing before it could be tricky.
It is also nice to clean the rockers too. There is so much you can do when changing a headgasket whilst everything is off.
#28
#29
Posted 19 January 2012 - 07:52 PM
#30
Posted 19 January 2012 - 07:55 PM
If you get yourself in gear you could have it done by monday :)
