Leaking Spark Plug?
thebullet
, Jan 27 2012 05:27 PM
10 replies to this topic
Posted 27 January 2012 - 05:27 PM
Changing the oil and managed to drop a bit down by one of the plugs, as soon as I started it was bubbling away untill the engine was turned off.
Is it because the plugs are fairly old and the washer has been crushed so many times that it dosen't seal anymore?
I can't imagine the leak to be right... defo in tight too.
Posted 27 January 2012 - 05:40 PM
If the plugs are that old replace them - only £12 for NGK
Posted 27 January 2012 - 05:41 PM
Well I say old, 11 years old ish, but not much use at all. But they have been in and out a fair few times.
Posted 27 January 2012 - 06:13 PM
Plugs should be replaced annually so yes, they are too old. You might find quite an improvement with new ones.
Posted 27 January 2012 - 06:16 PM
In what way improvement? :)
Posted 27 January 2012 - 06:18 PM
well if they are leaking around the seal better comprestion.
Posted 27 January 2012 - 06:21 PM
I wonder if my flat spot will go away
Posted 27 January 2012 - 06:41 PM
11 years! yes mate change them, they are part of a routine service
Posted 27 January 2012 - 06:49 PM
It sat in the garage for 10 of them, and probably was used with them a bit before.
Atleast if I change them about the same time as the oil it should be sweet.
It seems to love the Valvoline Vr1 :)
Posted 27 January 2012 - 06:50 PM
Is the oil in there 11 years?
Posted 27 January 2012 - 06:51 PM
No, the oil was changed October 2010. So it was about 16month olds, part sync, 10/40 :/
Should be better with this in.
Was overdue.
Was overdue.
