Rust Where The Inner Wing Meets The Scuttle
3 replies to this topic
#1 087dave
087dave
  • 443 posts
  • Local Club: irishminis.ie
Posted 06 February 2012 - 06:34 PM
Hi all, as the title says i have rust in this area, problem is i have replaced the wing already :ohno:
is there anyway i could repair the section
cherrs
#2 tiger99
tiger99
  • 1,124 posts
Posted 06 February 2012 - 07:45 PM
How about a picture, so the experts on that kind of repair can form a better opinion? Or, look through some of the rebuilds and restorations to see what others had to do.
The ultimate requirement is being able to get in there to clean, de-rust, measure, fit a patch, weld, prime, seam seal and paint. Can you do all that with the wing in place, with the equipment you have? Will the angle grinder or welding torch be useable in there? Try them and see, power off of course. And, can you weld upside down?
You may be able to save the wing, and put it back afterwards, if you very carefully drill out the spot welds. Got to be worth a try.
#3 sonikk4
sonikk4
  • TMF Staff
  • 3,408 posts
  • Local Club: EDMC
Posted 06 February 2012 - 08:14 PM
Dave do you mean the scuttle close out plate or the area around it. If so have a look at Project Paddy as i replaced the close out and repaired the upper flitch at the same time without removing the wing.
#4 087dave
087dave
  • 443 posts
Posted 06 February 2012 - 08:49 PM
Thanks for the replys, its where the scuttle meets the inner wing when you look from the engine bay where the two panels
meet
i could get at it without interfearing with the wing hopfully >_<
Thanks again
Mini Spares
