New Battery Needed
12 replies to this topic
#1 Piersp
Piersp
  • Just Joined
  • 77 posts
Posted 06 February 2012 - 10:03 PM
in the mini at the moment i have a Bosch silver 6E 0093s5640k, this just fits in on the length and on the sides with about a mm to spare on the sides, i was wonering eather anyone knows where i can sorce one of these from or of a battery that is better,
Thanks Piers
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 February 2012 - 10:04 PM
I always just used the smallest battery I could find - no point lugging extra weight about!
#3 Piersp
Piersp
  • Just Joined
  • 77 posts
Posted 06 February 2012 - 10:08 PM
what battery would you say is the best for being lightweight but still supply good CCA for starting?
#4 richw911
richw911
  • 2,084 posts
Posted 06 February 2012 - 10:13 PM
http://www.eurocarpa...57dd97fb
#5 minidave1991-89
minidave1991-89
  • 406 posts
  • Local Club: Charnwood Minis
Posted 06 February 2012 - 10:27 PM
I bought a tiny battery from halfords as bmcecosse said lighter the better. think it was about £45
#6 richw911
richw911
  • 2,084 posts
Posted 06 February 2012 - 10:30 PM
Use the code - Ukpas25 at euro car parts for 25% off the 075 battery i linked to above and get it for £47 for a Bosch, Nice snug fit in the mini battery box - but as said it well be heavier than a standard battery
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 February 2012 - 10:46 PM
how often do you use your mini ?
if you use it every day so the battery regularly gets topped up a small one will be fine, if you don't use your mini that often something that holds a bit more charge will be better
#8 minidave1991-89
minidave1991-89
  • 406 posts
Posted 07 February 2012 - 10:03 AM
I've got a battery which i bought brand new and have never put it in a car. Been in my garage about a year and a half. If i charged it back up do you think it would work or would the polarity etc be out?
#9 R1minimagic
R1minimagic
  • 4,660 posts
Posted 07 February 2012 - 10:10 AM
For CCA the bigger the better, no point having a lightweight battery unless you are racing, it will make no difference to performance whatsoever!!
(May fall through a rusty battery box quicker though :lol: )
#10 Cooperman
  • 23,513 posts
Posted 07 February 2012 - 10:31 AM
The ones I use have 530 CCA and are, I think, as fitted to a Peugeot diesel. Just measure it and go to a good battery supplier and see what they have that size, with good CCA and the terminals in the correct position.
#11 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 February 2012 - 05:34 PM
stick it on a charger and see what happens
but battery's don't like sitting around with no charge in them
#12 Piersp
Piersp
  • Just Joined
  • 77 posts
Posted 07 February 2012 - 06:15 PM
hi thanks for the fast reply's guys, i use it everyday usually do minimum in a day about 30 mile, also thanks for the euor parts code. the reason why i was looking for another bosch one that was idnetical was because of the CCA and it is as if its made to fit its so snug in the battery box you couldnt get any closer to all of the sides.
thanks Piers
#13 pothole
pothole
  • 317 posts
Posted 10 February 2012 - 01:34 PM
Thanks for this richw911 just ordered one and saved £15.
pothole
