Mini Spi Power Issue
7 replies to this topic
#1 kommander
kommander
  • 65 posts
Posted 07 February 2012 - 11:27 AM
Replaced vacuum hoses on Mini SPi, car starts and idles good, works good on a flat surface.
However, loss of power on inclines, car barely makes it up small hill on any gear except in reverse.
Any suggestions? Timing maybe?
#2 cooperdan
cooperdan
  • 2,676 posts
  • Local Club: N/A
Posted 07 February 2012 - 11:41 AM
So you replaced them all you say? and all the elbows and all the fittings are tight etc?
I wont be timing
#3 Racing Gold
Racing Gold
  • 43 posts
  • Local Club: Portsmouth and Southampton
Posted 07 February 2012 - 08:15 PM
Why did you change the hose? what was wrong to make you change them
#4 kommander
kommander
  • 65 posts
Posted 08 February 2012 - 12:16 PM
the engine was out of the car previous to it being bought.
when I received the car it drove home on limp mode.
on inspection the hoses were broken and not connected.
#5 kommander
kommander
  • 65 posts
Posted 04 April 2012 - 03:35 PM
any suggestions?
#6 xrocketengineer
xrocketengineer
  • 438 posts
Posted 04 April 2012 - 05:53 PM
Is the temperature gauge working? Do the symptoms get worse when the car is cold or warm?
#7 kommander
kommander
  • 65 posts
Posted 05 April 2012 - 09:18 AM
Yes the temperature gauge is working amd the engine temperature is fine.
When warm the car drives the same. Together with the lack of power, it repeatedly shuts off and needs restarting.
Would the position of the dizzy be an issue? The engine was out of the car before I bought it.
I'm thinking it was put back in the wrong position.
#8 Nu2mini
Nu2mini
  • 276 posts
Posted 05 April 2012 - 09:32 AM
This may help you
http://www.theminifo...ost__p__2373617
Mini Spares
