Minor Rust (I Think)..
6 replies to this topic
#1 mohammed
mohammed
  • 433 posts
Posted 07 February 2012 - 01:54 PM
Hi all, I never worked on a car body, never welded, or painted a car.. and I park my car outside no garage. I have few small rust spots on my mini and wanted some advice on what I can do.
Here are some pics:
under left headlight:
under right headlight:
right side mirror:
left side mirror:
bottom of rear window:
back bumber:
what should I do?
thank you
mohammed
#2 lapider
lapider
  • 473 posts
  • Local Club: cardiff mini club
Posted 07 February 2012 - 02:32 PM
chances are its only surface rust. no real damage there at the moment. get it touched up proffesionaly after sanding the paint and rust down or do it yourself if your confident i did it myself although i don't have metallic paint. the problem is your paint covering isnt going to protect the car as well as the original so in truth its a downward slope from here. if you were really serious you could get the whole door sprayed which will protect it but that may be a bit drastic.
#3 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 07 February 2012 - 02:45 PM
yeah, by the looks of things, its only surface rust, but the spots under the wings where it joins the front panel is a common spot for them to rust, and id investigate here further from behind the arch to check its okay inside, clean it all up in there and spray some stone chip etc on to help protect it. i use gravitex about £10 a litre..
the rest of the rust all looks fairly treatable..
#4 mohammed
mohammed
  • 433 posts
Posted 07 February 2012 - 02:52 PM
thanks everyone.. so i need to sand down, check for further damage, stone chip inside front panel, rust treat, prim and paint...might get paint done by a pro.
thanks
#5 JonnyBMX
JonnyBMX
  • 865 posts
Posted 07 February 2012 - 03:05 PM
stone chip the inside of the arch too! obviosuly make sure u clean all the mud etc off first... you got a compressor? easier to do with one of these :)
#6 analogue_radio
analogue_radio
  • 4,897 posts
Posted 07 February 2012 - 04:10 PM
Definitely do it now rather than later!
Looks very minor, but you won't really know until you take it back to bare metal and have a proper dig around.
#7 JonnyBMX
JonnyBMX
  • 865 posts
Posted 07 February 2012 - 04:17 PM
as he said make sure you go all the way back to clean metal and make sure that no rust is left!
