can you fit a rev counter to a mini that doesnt have one.. and how do you go about doing it ?
Rev Counter
alsy
, Feb 07 2012 08:30 PM
2 replies to this topic
Posted 07 February 2012 - 08:30 PM
Posted 07 February 2012 - 08:42 PM
Yes mount it and wire it to the coil
Posted 07 February 2012 - 09:07 PM
Yes you can,if you search the technical section on the forum you will get some top answers and a guide (i think) of how to wire one up.
It,s not too difficult if you take it step by step,(i did it). Depending on what type of ignition system is on the mini ie: points or electronic you have the choice of two. Once i had discovered that i had a points ignition system i fitted the correct Tachometer(rev counter) and found it ok.
