Another 'which Needles For This Set Up' Question
2 replies to this topic
#1 jameswhiles
jameswhiles
  • 304 posts
  • Local Club: A5 Minis
Posted 07 February 2012 - 09:40 PM
Hi all, ive got a 998 engine with...
LCB manifold
12g295 head
SW5 cam
I have got a set of twin 1 1/4 SU's and also the origional 1 1/2 SU (on a gas flowed manifold) Does anybody else have the same set up and if so what needles are you using in it as I would like to see for myself the torque differences between the 2 carb set ups.
Ive been led to believe that the GY's that came in the twins will work but thought I would see what other people recommend
Cheers :)
#2 oltonlad
oltonlad
  • 1,511 posts
  • Local Club: splinters mini club
Posted 07 February 2012 - 10:32 PM
on the single HS4 use an AAA needle, on the twin HS2's use the GY needles.
you will see a definate increase in torque with the twin carbs, i have a set of twin HS2's on our 1100 special and i wouldent go back to a single carb now.
both of these recommendations must be temporary until you get your car on the rollers to be set up properly but will work fine until then.
#3 jameswhiles
jameswhiles
  • 304 posts
Posted 08 February 2012 - 09:01 PM
The torque is what I'm after really so that sounds good. And I'm just seeing what others are using as a starting point for my set up, cheers bud :)
Mini Spares
