Electrical Problem! Help
10 replies to this topic
#1 OldBetty1979
OldBetty1979
  • 134 posts
Posted 07 February 2012 - 10:11 PM
Okay so I went snow drifting in the mini and think I have ******* my electrics..
When I touch the dizzy or near the coil I get a electric shock...
The 1 & 2 fuse blew, might be nothing to do with it though :S
Anyone know anything I can do to find out the problem?
Thanks in advance :)
#2 lrostoke
lrostoke
  • 5,149 posts
Posted 07 February 2012 - 10:16 PM
yes dry it out :)
wet and electrics causes shorts
#3 cooperdan
cooperdan
  • 2,676 posts
  • Local Club: N/A
Posted 07 February 2012 - 10:33 PM
hahaha, fare play..
as said just dry them out, touch wd40 and see where you get...
#4 OldBetty1979
OldBetty1979
  • 134 posts
Posted 08 February 2012 - 04:35 PM
Yeah I dried it out sprayed it with WD40 ran okay then sprayed it down with the hose cause grit was everywhere, then had the problem again water is making it ark out(Think that is what it's called) Can't leave it how it is cause one bit of water and it will just keep doing it... Think I'm going to change the dizzy and leads see how it goes if still doing it then change the coil then I have no idea :mmkay:
#5 Dan
Dan
    TMFs Chief Doc
  • Mini Docs
  • 17,316 posts
Posted 08 February 2012 - 04:44 PM
'It wasn't working well because it was damp, so I dried it and it worked fine. Then I sprayed it with water again and it started playing up again'
Stop touching the wet 3000 volt transformer or spraying water on it and you might find you stop getting electric shocks and arcs. Clean the grease and dirt off it all, dry it, fit the water shield back to it and see if there is actually a problem before you do anything drastic.
#6 R1minimagic
R1minimagic
  • 4,267 posts
Posted 08 February 2012 - 04:48 PM
Love it! :lol: :lol:
#7 JonnyBMX
JonnyBMX
  • 448 posts
  • Local Club: Rebels
Posted 08 February 2012 - 05:00 PM
ahah! yeah best to keep minis dry! i know there is a way to get away from using points? some kinda magnetic thing used in the distributor? not sure about that one though not used it myself
#8 ryan22_lgm
ryan22_lgm
  • 434 posts
Posted 08 February 2012 - 05:50 PM
electronic ignition will solve having to adjust the points all the time but wont stop it arcing out when its wet all over the front of the engine wiring. best thing is a weater shield and wd40 before going out in wet conditions :)
#9 OldBetty1979
OldBetty1979
  • 134 posts
Posted 08 February 2012 - 07:01 PM
Yeah I wrote that wrong,I did dry it and spray WD40 over it but it was still giving an electric shock. It never use to do it before so something has to of gone wrong? I'm going to replace the leads and stuff anyway they're old and shitty..
#10 Dan
Dan
    TMFs Chief Doc
  • Mini Docs
  • 17,316 posts
Posted 08 February 2012 - 07:45 PM
Fair enough but if it's really wet rather than damp then WD40 won't do anything anyway. It really is probably just dirt (dirt absorbs water, WD40 traps more dirt which in turn absorbs more water), but old and worn leads could be breaking down. Do you have a weather shield?
#11 OldBetty1979
OldBetty1979
  • 134 posts
Posted 08 February 2012 - 07:56 PM
Okay well buying new parts for it anyway and the rest I'll just take off and clean. No I don't have one, need to get one of those as well.
Mini Spares
