What Might The Damage Be Here?
15 replies to this topic
#1 jiminwatford
jiminwatford
  • 209 posts
Posted 07 February 2012 - 11:28 PM
I'm 113 miles away from this mini so can't easily go and have a look.
What might be damaged on the rear wheel? will it definately be the subframe? or maybe just part of the arm? :goaway:
Edited by jiminwatford, 07 February 2012 - 11:28 PM.
#2 cooperdan
cooperdan
  • 2,676 posts
  • Local Club: N/A
Posted 07 February 2012 - 11:32 PM
potentially no.....but still hard to really tell,
is it possible to ask to get a photo from underneath
#3 bmcecosse
bmcecosse
  • 8,310 posts
Posted 07 February 2012 - 11:33 PM
Definitely will be subby damage - but also the subby may have pulled away from (and damaged) the heel board. New bodyshell and rear subby should soon have it back on the road again! And then you will have a 'new' mini on the road for ~ £7000 - including the £250 or so to buy that one.........
#4 jiminwatford
jiminwatford
  • 209 posts
Posted 07 February 2012 - 11:34 PM
I don't think so. It's at Copart and is in auction tomorrow. I won;t get any closer until i've bought it :(
#5 jiminwatford
jiminwatford
  • 209 posts
Posted 07 February 2012 - 11:35 PM
I think it be a lot more than £250..
The shell is a mess so it would be for parts. It's just with a badly damaged subframe it makes it a little more drastic,
Edited by jiminwatford, 07 February 2012 - 11:35 PM.
#6 hobnob888
hobnob888
  • 168 posts
well if it goes cheap, you can always use it for spares....
#7 matty...
matty...
  • 327 posts
  • Local Club: Turbominis
Posted 08 February 2012 - 12:03 AM
Thats criminal to write a shell off for that damage!
Its more than likely going to be a bent radius arm, radius arm bracket, or if your unlucky the subframe. If the heel board was to be damaged, its nothing a repair section couldn't fix either. If your handy with bodywork, its nothing more than a few hundred quid in panels. Once that quarter is removed, that rear panel wouldn't be too hard to pull out, if the arch needs replacing thats simple enough with the quater panel removed also.
Considering what rot boxes sell for these days, that would definitely be worth a punt at that price.
#8 Cooperman
  • 8,237 posts
Posted 08 February 2012 - 12:21 AM
Worst scenario is take out the rear sub-frame, get the shell into a body jig for accurate repair, fit new rear sub-frame and, if bent, the rear arm. Fit any replacement front suspension parts and a new front sub-frame in the unlikely event of that being bent too.
A good time to get rid of that inefficient exhaust system too.
#9 benb12
benb12
  • 1,473 posts
Posted 08 February 2012 - 12:25 AM
Looking at it on copart there is similar damage to the o/s rear quarter/rear panel too. It would be a lot of work, but not beyond some people on here. I'm surprised it's only a cat C though.
#10 JonnyBMX
JonnyBMX
  • 448 posts
  • Local Club: Rebels
Posted 08 February 2012 - 08:44 AM
also got the damage at the front, new front panel, new wing? has it pushed any of the floor pan up or damanged the scuttle or windscreen surround? inner wing okay? obviously a very big job to get that back on the road! but people can do it :)
#11 reallybig
reallybig
  • 414 posts
Posted 08 February 2012 - 12:05 PM
What this guy said, my mini looked better but was in far worse condition under the surface
#12 chrisandsarah
chrisandsarah
  • 662 posts
Posted 08 February 2012 - 01:43 PM
I don't recon its a gonner - just needs some work done exactly like matty says!
#13 R1minimagic
R1minimagic
  • 4,267 posts
Posted 08 February 2012 - 01:51 PM
It looks like the impact is higher up so the subby could actually be ok...i would be more worried about the wheelarch
#14 jiminwatford
jiminwatford
  • 209 posts
Posted 08 February 2012 - 01:53 PM
Whoever won the auction will now have to find out ;)
#15 reallybig
reallybig
  • 414 posts
Posted 08 February 2012 - 02:07 PM
awww how much it go for then
Mini Spares
