Exhaust Fitting
9 replies to this topic
#1 mow
mow
  • 14 posts
Posted 08 February 2012 - 11:28 AM
Hi, I'm looking at ordering a twin box rc40 but can't decide on centre or side exit. Are there ground clearance issues with the centre exit?
Currently running 12's with stock suspension.
thanks mow
#2 thebullet
thebullet
  • 1,098 posts
Posted 08 February 2012 - 11:59 AM
I have just fitted a centre maniflow with 12" wheels, no clearance issues so far, just go steady on speed bumps and rough ground and you will be fine.
#3 AVV IT
AVV IT
  • 3,053 posts
Posted 08 February 2012 - 12:04 PM
I don't think that there would be any real ground clearance difference between the two. Due to the rear suspension generally sitting higher than the front, in my experience all the exhaust ground clearance issues tend to happen nearer the front of the car. Particularly if you can't align the damn thing to tuck away into the floor tunnel properly and even more so if you've got a later model with a CAT fitted.
I also seem to remember reading that in tests, the side exit item gave slightly better performance than the centre exit version. Also bare in mind that if you currently have a side exit system, you will probably need to drill the rear subframe in order to fit a centre exit version.
Edited by AVV IT, 08 February 2012 - 12:06 PM.
#4 thebullet
thebullet
  • 1,098 posts
Posted 08 February 2012 - 12:06 PM
Mine already has the holes at the back of the subframe.
Do what I did, twisted the first bracket on its side and tightened it, keeps the longest part with the threads from getting ripped off on the ground.
Edited by thebullet, 08 February 2012 - 12:06 PM.
#5 AVV IT
AVV IT
  • 3,053 posts
Posted 08 February 2012 - 12:09 PM
Do you mean the U bolt clamp, that joins the LCB to the down pipe? :unsure: (as below)
#6 thebullet
thebullet
  • 1,098 posts
Posted 08 February 2012 - 12:11 PM
Yeah! Couldn't think of the name :shy: Just the first one which attaches to the manifold. Still very tight, or I wouldn't have done it, but it means on its side it won't have as much chance to drag on the floor.
Edited by thebullet, 08 February 2012 - 12:12 PM.
#7 AVV IT
AVV IT
  • 3,053 posts
Posted 08 February 2012 - 12:13 PM
Yeah that's not a bad idea :thumbsup: ... It's a fairly obvious thing to do when you think about it too... >_<
#8 thebullet
thebullet
  • 1,098 posts
Posted 08 February 2012 - 12:14 PM
It is, after that they are all straight but then the exhaust gets higher into the body.
#9 mow
mow
  • 14 posts
Posted 08 February 2012 - 12:38 PM
Thanks for that, sounds like careful fitting is the key either way.
#10 freshairmini
freshairmini
  • 847 posts
Posted 08 February 2012 - 01:16 PM
basically just do it methodically and think about it before fitting! :P
Mini Spares
