Metro Engine - Heater Hose In The Way :(
3 replies to this topic
#1 chrisandsarah
chrisandsarah
  • 662 posts
Posted 08 February 2012 - 02:16 PM
Rover Mini City 1992
1275 Metro Engine stage 1
I want to fit a ultimate engine steady to the thermostat side of the engine. However, the engine steady I bought does not fit as the heater outlet pipe feeds to the thermostat sandwich plate, which in turn gets in the way of my steady.
Is it possible to change where that pipe goes - or should I spend some money on a steady that is speciffic to the sandwich plate metro thermostat?
I believe that this is the steady I bought (from elsewhere) http://www.minisport.../info_EL58.html
That however clashes with the heater matrix outlet pipe as shown in the pic below:
#2 chrisandsarah
chrisandsarah
  • 662 posts
Posted 08 February 2012 - 02:32 PM
If I was to fit this - http://www.minispare...id=32760&title= does it look like I have a 'PEQ10019 large bore thermostat housing' fitted?
#3 chrisandsarah
chrisandsarah
  • 662 posts
Posted 08 February 2012 - 03:43 PM
Problem solved - called Minispares. Turns out I have a thermostat housing that will take the steady above - so waiting on the order now :D
#4 reallybig
reallybig
  • 414 posts
Posted 08 February 2012 - 06:06 PM
:P
Mini Spares
