Replacing Rear Quarter Panel - Welding Method Advice?
7 replies to this topic
#1 colinu
colinu
  • 191 posts
Posted 08 February 2012 - 09:48 PM
Floor pans almost complete - next job will be cutting out and replacing rotten rear quarter panels. Should be a relatively straight forward job, but I'm unsure on what type/method of weld to use on the rear external seams. From factory I believe these were continuous spot weld, but I don't have the equipment to achieve that (I'm using MIG). What alternative methods should I use?
E.G.
a) plug weld with inch spacing
b) as above but additionally run a continuous seam internally
c) buy a spot welder and attempt a continuous spot weld
d) other suggestions???
Cheers,
Colin.
#2 sonikk4
sonikk4
  • TMF Staff
  • 3,411 posts
  • Local Club: EDMC
Posted 08 February 2012 - 09:51 PM
If you have a spot welder then you can do a combination of spot welds and plug welds. Otherwise like i did plug weld with inch spacing.
#3 colinu
colinu
  • 191 posts
Posted 08 February 2012 - 10:15 PM
OK - plug weld works for me :)
#4 bluesprite
bluesprite
  • 240 posts
Posted 08 February 2012 - 10:18 PM
If you're confident working with mains electricity then you could have a go at building a spot welder
http://www.instructa...lder-Portable-/
If any of the instructions/parts aren't clear to you then I'd probably not bother because Microwave transformers can easily be lethal if you don't know what you're doing.
It should cost less than £10 if you can find an old microwave.
Edited by bluesprite, 08 February 2012 - 10:19 PM.
#5 Tupers
Tupers
  • 1,759 posts
Posted 08 February 2012 - 10:19 PM
As above plug weld every inch or maybe a little closer.
#6 Tupers
Tupers
  • 1,759 posts
Posted 08 February 2012 - 10:21 PM
That looks like a very drawn out way of killing yourself.
#7 sonikk4
sonikk4
  • TMF Staff
  • 3,411 posts
  • Local Club: EDMC
Posted 08 February 2012 - 10:26 PM
To be honest and from a safety point of view don't attempt to build your own. Just looking at one that was made showed no covering over live components. Fair play the OP mentioned that unless you were a skilled electrician it can be lethal. If it was to fail or damage you your car or your house then there would be no insurance company in the world who would pay out.
#8 colinu
colinu
  • 191 posts
Posted 08 February 2012 - 11:04 PM
As much as I like Instructables (and am fully capable/skilled to build one) I have to agree with sonik - it's an accident and legal liability just waiting to happen. If I were to go down the spot weld route then I'll buy one from my local tool store for $160 (100 quid) and feel a lot safer.
Mini Spares
