Helppppppppp Meeeeee !
6 replies to this topic
#1 bjarthur69
bjarthur69
  • 54 posts
Posted 08 February 2012 - 10:25 PM
basicaly i am looking for someone who knows somthing about mopeds my problem is some of the electrics arent working now i have forund a buyer but he said he would take it if had the electrics looked at its had a new cdi,regulator,i have had a mechanic friend of mine look at it we went over all of the earths and fuses and made sure he battery is charged any hep is great ps:i want to sell it so i can buy a !!!! MINI !!!! yayyyyyy so please help if you can and heres a just because i canAttached File  268427_245442572147890_100000464482050_1073950_5779316_n.jpg   121.5K   5 downloads
#2 Magic jason
Magic jason
  • 522 posts
Posted 08 February 2012 - 10:45 PM
haha the only things i know about moped are they hold you up, they cut you up and when they hit you they end up falling to bits! and the you have the guy accusing you because he thought he would be a right chavy W***** and swerve in between traffic!
#3 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 08 February 2012 - 11:00 PM
Are any of the electrics working? Try joining a wire from the engine casing to the frame and see if anything happens.
#4 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 08 February 2012 - 11:03 PM
remove the exterior panels and check each wire connection for corrosion or not being attached correctly. apply wd40 to the connections. should sovle the problems
#5 MiniFTW
MiniFTW
  • 697 posts
Posted 08 February 2012 - 11:18 PM
Turn it off. Then turn it on again? It's never failed me.
#6 bjarthur69
bjarthur69
  • 54 posts
Posted 09 February 2012 - 09:30 AM
well yes the lights work on one setting and the brake lights but thats about it what needs to work is the indicators,electric start,some headllight settings fuel guage
#7 Masoa010
Masoa010
  • 99 posts
  • Local Club: Mini Freakz of Sussex
Posted 09 February 2012 - 09:43 AM
I used to have a yahama Aerox, found the easiest way to solve stuff was to just remove every panel, otherwise you spend forever looking for the right bit. Check the connections on the switches, for the start button as they get covered in stuff so they go pretty easily
