Engine Keeps Cutting Out When Waiting At Lights Etc
minifan2012
, Feb 08 2012 10:28 PM
9 replies to this topic
Posted 08 February 2012 - 10:28 PM
hi I have a 1994 mini monte carlo and when I slow down or stop the engine cuts out or stalls. I have just had it serviced (Today) and I have used a petrol cleaner as well but I cant seem to solve the problem. Any Ideas on whats wrong or how to fix it would be really appreciated.
Posted 08 February 2012 - 10:35 PM
is it an spi? if so have you checked the vacuum pipe coming from the ecu for any splits or holes.
Posted 08 February 2012 - 11:08 PM
My MPI was doing that, it was the idle control unit, its gone twice now. Replaced it and I can coast up to every junction no problems.
Posted 08 February 2012 - 11:23 PM
got the right dizzy and timing?
ignition coil going?
high enough voltage going to the electronic ignition on the dizzy?
Posted 09 February 2012 - 08:12 AM
Is this carb or spi? My 94 mini 35 used to do that. It was a simple solution to adjusting the fuel. The carb was flooding the engine, it was fine if you kept the revs up.
Posted 09 February 2012 - 08:40 AM
Hi everyone thanks so much for your help. The car has an automatic choke, I have checked for any obvious splits but Am new to this so go with my haynes manual in hand. I think it could be the ignition timming but I will investigate further and let you all know how I get on.
Posted 09 February 2012 - 03:55 PM
the care is injection
Posted 12 February 2012 - 06:10 PM
My Mini 35 has done this a couple of times but infrequently...always when she is cold and it's chilly, like another poster if I kept the revs on a bit it stopped doing it.
Posted 12 February 2012 - 06:34 PM
as said above could be idling too slow or hav a broken control unit? mines a carb but i adjusted my idle speed too low and it did this, i dont know how to adjust it on injections though sorry.
Edited by dennismini93, 12 February 2012 - 06:35 PM.
Posted 19 February 2012 - 07:19 PM
I have finally got my mini back working
. There was air in the clutch, and the earth leads were rusted up giving a poor connection causing the car to stall .
