Shocks
Posted 09 February 2012 - 12:05 AM
Posted 09 February 2012 - 12:26 AM
As far as brands go Spax are one of the best before you start getting into mega ££££ set-ups, I'd stick with them.
Posted 09 February 2012 - 12:34 AM
Posted 09 February 2012 - 01:29 AM
http://www.protechsh...nt-rear-package
Edited by J322OverTheTop, 09 February 2012 - 01:30 AM.
Posted 09 February 2012 - 09:59 AM
Posted 09 February 2012 - 10:13 AM
surfblue63, on 09 February 2012 - 12:34 AM, said:
I have these too. Looking through the sets available from Minispares, they only cost a little more than the standard oil ones, so it seemed a good upgrade. They seem comfortable on my daily car.
Posted 09 February 2012 - 11:04 AM
Posted 09 February 2012 - 01:04 PM
Posted 09 February 2012 - 01:12 PM
minimad91, on 09 February 2012 - 01:04 PM, said:
Are the spax ones you have adjustable, if so what setting do you have them on? (how many clicks?)
Posted 09 February 2012 - 01:19 PM
Posted 09 February 2012 - 01:34 PM
Posted 09 February 2012 - 10:52 PM
The ideal damper will have seperate adjustment for bump and rebound, but I am not sure if anyome makes those for a Mini. (You do get them for some more modern cars.) But getting the correct damping rate on suspension with a very variable spring rate is well-nigh impossible anyway. You need to set them up for the car as it is normally loaded, but if carrying a full load it will then be underdamped. Or, if you set them up for a full load, because that is what you mostly carry, with the driver alone they will be horribly hard. Suspension design is always a multitude of compromises.....
The only way of getting the spring and damper rates right under all load conditions with such short travel suspension is to go for self-levelling hydropneumatic, like a Citroen. I keep wondering if that would be possible on a Mini.
Posted 09 February 2012 - 10:55 PM
I have these and easy to adjust.
GAZ ADJUSTABLE
Edited by toplessmini, 09 February 2012 - 10:57 PM.
Posted 10 February 2012 - 10:07 AM
when i bought them
got spax on my road car setting front no.5 bit bumby but its second car for fun
