edit (cant do it above?!), found a few more reports about Ka and Fiesta UJ's fitting so will look at trying one, not too keen on the hex shaft idea but will see if I can't find a spline to spline one!
Tilted Steering Wheel
PushingTin
, Feb 16 2012 07:06 PM
24 replies to this topic
#16
Posted 05 March 2012 - 07:29 PM
#17
Posted 05 March 2012 - 08:06 PM
Hi, it takes a m8 pinch bolt, Ford Finis Number- 7257202. They are on eBay, Ka's upto 2008 I think.
#18
Posted 05 March 2012 - 08:12 PM
If you want spline to spline, look into defender steering uj, or disco / rr classic etc... As I am 99% they are of same (rover) spec. Might be wrong but worth a size up! Cheers
#19
Posted 06 March 2012 - 02:43 PM
Does anyone know what the spline 'is' spec wise on the mini column?
PT
PT
#20
Posted 06 March 2012 - 06:44 PM
I remembered to measure one out of an old rack today, I make it 9/16 diameter, 36 teeth on the spline, will try and find out if landy ones are the same, they look it from my memory of changing them all the time in my defender!!!
#21
Posted 06 March 2012 - 06:59 PM
Hi there, I bought a uj from car builder solutions and it fits on the standard mini rack, will find out the part and link for you.
#22
Posted 06 March 2012 - 07:10 PM
Sorry it wasnt car builder solutions for the spline piece it was this one: http://www.ebay.co.u...=item230410881f
The I bought some stainless steel bar 19mm diametre, thats sits perfect in the adaptor and is welded in, cut to the right lenght then a stainless UJ with solid ends was drilled and welded on the other end of the bar. Then a second bar welded into the UJ going to a quick release steering wheel hub.
Car builder solutions do the UJs and then I got some 19mm rose joints to support the shafts. Hope that helps.
#23
Posted 06 March 2012 - 07:14 PM
Heres the bar: http://www.ebay.co.u...=item3ef22263fe
And the rose joints: http://www.ebay.co.u...=item255fe35535
Edited by benmoffat, 06 March 2012 - 07:18 PM.
#24
Posted 07 March 2012 - 12:15 AM
What material is that spline end made from?
#25
Posted 27 August 2012 - 09:48 PM
Thanks for all this info evryone. make live all the more easier,
