Servicing My Mini.
24 replies to this topic
#16 Ethel
  • 26,580 posts
Posted 20 February 2012 - 12:22 AM
I can see a "debate" kicking off,
I wouldn't use engine flush routinely either; it won't get at any gunge in the oil galleries, which would be far more critical than anything washed off the inside of the block. Worse, thanks to the Mini's "combined transmission" it could displace oil from the gearbox's hard to reach places, like the layshaft bearings.
Another advantage of doing your own servicing is that you won't need to replace as many parts as often. Plugs, points etc only get changed because the can't be relied on to last until the next service. Since you can sort them in minutes, if needs be at the side of the road, why throw away perfectly function components?
Skipper's world,
Check out Youtube as well, I'd recommend University Motors channel, it may be aimed at MG owners but a lot of it applies just as well to the A Series in your Mini.
#17 skippersworld
skippersworld
  • 205 posts
  • Local Club: Not Yet
Posted 20 February 2012 - 07:06 AM
Just read through all that has been said!!
As you all say, i will be reading through the haynes manual before doing anything, grab myself some tools and go from there!!
Thanks a lot guys, much appreciated!!!
#18 skippersworld
skippersworld
  • 205 posts
Also, would halfords do all the bits i will need for this? or am i better off getting things online?
Thanks.
#19 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 20 February 2012 - 07:12 AM
yeah halfrauds do the bits. do you have a traders card?
#20 skippersworld
skippersworld
  • 205 posts
Posted 20 February 2012 - 07:21 AM
Nope no traders card, whats this for?
#21 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 20 February 2012 - 07:22 AM
oh and WATCH IT ALL don't just dismiss it (lol i know its a bit cheesy) :D
#22 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 20 February 2012 - 07:57 AM
engine flush your choice
#23 jakejakejake1
jakejakejake1
  • 644 posts
Posted 20 February 2012 - 05:33 PM
Unipart are cheaper than halfords for some parts (if you don't have a trade card) also you could order the parts from a mini supplier online. All the jobs are easily done at home, and the money you save could get you a nice set of spanners etc, which in turn will allow you to save more money in the future by doing more jobs yourself.
#24 jimnali
jimnali
  • 260 posts
Posted 20 February 2012 - 06:21 PM
You should also check and consider replacing the air filter and plug leads.
Good luck!
#25 Cooperman
  • 23,513 posts
Posted 20 February 2012 - 07:14 PM
If you want to use an engine flush and you have an oil cooler, you MUST take the cooler right off after flushing as the cooler will retain its old oil if not removed and turned upside down to drain. You don't want residual flushing oil in the engine for normal running.
