Just lapping a ball joint for the first time and wondered how long I need to keep going. Hopefully the photos will show where I'm up to. The cup has developed a small polished section from top to bottom, about 2mm wide The rest is still matt. The ball has a polished strip 2-3mm wide all round the circumferance. I've been lapping by hand. Should I keep going in order to polish the cup all the way round ???
Lapping Ball Joint
Posted 26 February 2012 - 08:13 PM
Posted 26 February 2012 - 08:20 PM
Posted 26 February 2012 - 08:22 PM
Posted 26 February 2012 - 08:31 PM
30 secs normally does it
Edited by charie t, 26 February 2012 - 08:32 PM.
Posted 26 February 2012 - 08:44 PM
I've stopped because I've had enough using rubbing compound for paint work. I will get some grining paste tomorrow. Will this be more aggressive ???Are you actually using any grinding paste?
Posted 26 February 2012 - 08:50 PM
Posted 26 February 2012 - 09:13 PM
Posted 26 February 2012 - 09:14 PM
Right then down to the motor factors on the morrowyes very much so
Posted 26 February 2012 - 09:43 PM
If you gave up because of that, you'll be even more fed up trying to lap it in without pasteI've stopped because I've had enough using rubbing compound for paint work.
Posted 26 February 2012 - 10:21 PM
Posted 26 February 2012 - 10:29 PM
Some people insist on them being tighter, but those I have done all lasted at least 60k miles, and did not knock or rattle. A thou of free play does no harm, any more and if the shims can't set it accurately enough, you can lap a little bit off the flat face of the ball nut to tighten it up slightly. You would do that lapping on a sheet of abrasive paper taped to a very flat surface such as a piece of plate glass, or on a carpenter's oilstone.
