what size is the sterring wheel nut on a 93 and 94 sprite 1275 carb? thanks
silly question lol
lewis
, May 17 2004 06:32 PM
12 replies to this topic
Posted 17 May 2004 - 06:32 PM
Posted 17 May 2004 - 07:56 PM
Pretty sure all steering wheel nuts are one and five sixteenths..
Posted 17 May 2004 - 09:14 PM
cheers do you know what that is in mm, 22m etc
Posted 17 May 2004 - 09:23 PM
34mm...
Posted 17 May 2004 - 09:30 PM
thats big, once the bolts removed do you have to get a new bolt, looks like its self locking
Posted 18 May 2004 - 06:50 AM
bolt?
If you mean the nut, you should be able to use the same one with no problem....
Posted 21 May 2004 - 08:05 PM
i need to fit a new steering wheel, ive got a boss for it, but will i need the original steering wheel nut aswel as the boss
Posted 22 May 2004 - 08:28 AM
Take off nut, keep it. Lift away old wheel (and boss if there is), chuck them away. Place new boss on the column, refit nut. Bolt new wheel to boss.
Jobs a good'un! :wink:
Posted 23 May 2004 - 09:43 PM
Make sure you leave the nut on a couple of turns when pulling the wheel towards you. If you don't make sure the wheel is loose on its splines before completely removing the wheel, it can suddenly come off and hit you right in the gob! Yes, I do speak from experience here
Posted 02 June 2004 - 06:26 PM
r u sure its 34mm, becos i measured it and it was about 26mm
Posted 02 June 2004 - 09:08 PM
is there a trick to gettin it off, because mine's being a b****rd, it wont budge
Posted 03 June 2004 - 06:12 AM
Just get the biggest socket wrench or bar you can get your hands on, turn the wheels to full lock (left) and/or chock em with something to stop any movement, and then just use all your strength to undo it. It should pop... using a mallet or hammer can help.
If it really really doesnt want to go, i guess you could attempt to either break it with a chisel, or you could cut it off with a grinder (but you would have to be VERY careful not to damage the thread)
Posted 03 June 2004 - 09:16 PM
its ok people, ive done it :tongue: i used an extension, leverage really helps
